Rolling Codes & CAN?
I'm working on a project where I use two Arduinos together, one gathering sensor data and sending it to the other, which sends data packets out over a CAN network.
I'm wondering if anyone has suggestions - or an application note, or anything, for that matter - on how to use rolling codes to ensure that the devices are not tampered with. I want to use CAN ultimately (using a CAN shield on a Duemilanove), but uart would work for now, so I can get a feel for how it works.
I know I will need a button on each device to synchronize the seed, but I am not sure on what type of algorithm the code must take. I understand most devices use a common seed and a formula programmed into both devices, with the device that does the "reading" of the code storing the next ~3-5 codes in memory (so if it misses due to network traffic/interference, it still responds for a bit). If the devices become disconnected for more than those 3-5 expected responses, it sets a bit (turns on a buzzer or a light, in my case) and lets the operator know that the devices are no longer synchronized.
I'm concerned about the rolling code algorithm lagging the Arduino. I want this "secure" functionality, but it is secondary to gathering and logging the data from my sensors. Is this feasible?
Secondly, I tried a quick search but couldn't find anything - does the Arduino have a "code fuse" to prevent reflashing?
Thank you!
What kind of tampering are you trying to detect?
I'm trying to figure out if the device is disconnected from the sensor, even for a second. Unfortunately, a check for a zero value is not a good enough solution in my eyes. What I'm envisioning, is a CAN sensor hooked to one Arduino and that Arduino talking to a second Arduino, also over CAN. If the the first Arduino is disconnected from the sensor, the second Arduino would then (using a rolling code or similar) be able to tell that the first Arduino was missing, a set some sort of flag.
If you only want to detect a disconnection (a dropped frame), a simple sequence number will work.
