ROM-Reader for Super Nintendo / Super Famicom Game Cartridges
3.3V selected on the Cart Reader should be fine and then any USB port to provide power to the Cart Reader.
Just wondering Sanni if you can get these carts flashed?? The first one is a N64 Flash cart and the other is a Sega Genesis Repro.
The current code for flashing Sega Mega Drive/Genesis repros is just an example and not based on any real-world repros, simply because I don't own any. That being said it should not be too hard to change it to match the repro pictured above. Just check the datasheet of the ST flash to see what code changes need to be done.
For this specific N64 repro, you probably would need to build an adapter as it doesn't seem that you can flash the repro from the N64 cartridge edge and the programmer cart edge will have a completely different pinout not matching my Cart Reader without an adapter in-between.
Hi sanni,
Just curious. Why did you disabled internal pull up of buttons and placed 10kohm registor pull ups? Maybe you can remove two 10kohm registors to save some space on board.
Thanks, tamanegi_taro
Yes that will work too. :)
Hi guys, earlier in the topic i made a post with a question I didn't quite get an answer to yet, so I wish to ask it again please, can the cart reader be set up to work with NES and/or Sega 32X games (that is, being able to read/write to either of these kind of cartridges)? I'm presuming the latter will work with the Sega Genesis/Megadrive slot (I've heard that the Retrode2 can work with Sega 32X cartridges even though the top part of it has to be temporarily removed for best results)?
Thanks in advance.
KnightofTime: Hi guys, earlier in the topic i made a post with a question I didn't quite get an answer to yet, so I wish to ask it again please, can the cart reader be set up to work with NES and/or Sega 32X games (that is, being able to read/write to either of these kind of cartridges)? I'm presuming the latter will work with the Sega Genesis/Megadrive slot (I've heard that the Retrode2 can work with Sega 32X cartridges even though the top part of it has to be temporarily removed for best results)?
Thanks in advance.
If you write the code for it and build an adapter, sure. But right now it only supports the stuff listed under features.
Just buy an INLretro programmer-dumper instead, afaik it can already read NES and MD/32x will probably follow soon.
Hi, i recently installed the N64 slot on the shield But i get error in some games when i read the cartridge
List
Zelda Majora's Mask (Brazilian Gradiente Release) - ERROR International Super Star Soccer '98 - ERROR Banjo Tooie (Brazilian Gradiente Release) - ERROR Pokemon Stadium 2 - ERROR Mario Kart 64 - ERROR Shadow Man (Brazilian Gradiente Release) - ERROR
San Francisco Rush Extreme Racing - OK Dark Rift - OK Star Wars Episode I Racer - OK Fifa Soccer 64 - OK Pokemon Stadium - OK
What will could be?
Thanks a lot
Could be several things: - the dumped rom is correct but crc32 is not found in n64.txt -> google for the crc32 to see if it is listed as a valid dump - the dumped rom is incorrect because the cartridge is not inserted dead center into the slot -> use the 3d printed sleeve for the n64 slot to make sure carts are always aligned - the dumped rom is incorrect because you accidentally used 5V instead of 3.3V or forgot to desolder the two components from the Arduino Mega allowing it to run at 3.3V - dump is incorrect because there is a bad contact in the 3.3V line -> use a multimeter and measure the resistance between the two points marked by red circles while the cart reader is switched to ON and 3.3V but not connected to a power source, it must be around 0.5 Ohm but not over 1 Ohm, if it is over 1 Ohm you need to switch the switches on and off a few times to remove corrosion or even resolder the connections: |500x435 -the dumped rom is incorrect because the Arduino Mega you're using can't handle 3.3V very well -> you can reflash the Arduino Mega's fuses to disable the brown out fuse. - the dumped rom is incorrect because there still might be an error in my dumping code that only affects certain cartridges
Sanni
I’m using the original N64 Slot
I gently sand all contacts on the 64 slot using a credit card and a very fine sandpaper
All games start do detect except ShadowMan
I measured the resistence, it's about 0,6ohms
I think the 3.3v rail is ok, because today i did some snes repro carts
Sanni, do you know whether the type 2 mbc3 + rtc cart here https://www.tindie.com/products/JRodrigo/pre-modded-flash-cartridge-with-mbc3-rtc-timer/ is compatible with the cart writer?
Type 2: Type 2 - TSOP-II-44 ROM - PCB mark DMG-KGDU-01
Yes they should be compatible.
sanni: If you write the code for it and build an adapter, sure. But right now it only supports the stuff listed under features.
It's possible I might buy the INLretro programmer-dumper someday, thanks for telling me about it sanni (I have been talking to the guy behind the creation of it on Facebook (Infinite NES Lives); he is working on an official release that he hopes will be ready in January).
Now, being as I'm ready to purchase one of moldov's cart readers soon (hopefully this month if possible), I have a couple more questions about the cart reader, one, will I need to update the firmware once I receive it, and two, just in case there isn't an SD card included with the cart reader, will a 2GB SD (not SDHC) card work okay? I have a couple of Lexar SD cards that are 2GB each.
If you need to update the firmware depends on what firmware is currently installed. I have not worked on a new version of the firmware for about a month and I'm not currently working on a new version. I have tested the Cart Reader with a 2GB SD from Toshiba without SDHC and while it worked it slowed down the Cart Reader a little but maybe that was just because it was a slow SD card and had nothing to do with SDHC missing.
Sanni
You could add a topic on Wiki called "Some fixes" and put some infos, just like what i did to fix the N64 using only a sandpaper
I would help you sending some pictures and making a small tutorial to show how to fix the connectors or jump the 29LV320 snes repro
Thanks
Hi Sanni,
Is it possible to write bsx rom packs with satellaview already dumped roms and actually run through the original cart?
I don't have any BSX stuff myself but from my understanding that is exactly what the Satellaview code is for. You need the game "BS-X: Sore wa Namae o Nusumareta Machi no Monogatari" as an adapter between the Satellaview 8M Memory pack and the SNES slot of the Cart Reader.
ViniNess: Sanni
Thanks
Good idea, I made a new entry in the wiki called useful forum posts, from where I will link to some posts here. So just write your tutorial here and I'll link it in the wiki.
--- Fixing Bad Cartridge Slot Contacts ---
When you recycle some old game cartridge slot you always get from junk video games, and some times the contacts are not good because of corrosion.
But don't worry it's easy to fix
You will need a very fine sandpaper and a credit card (or any PVC card with the same thickness) |500x281
Cut the sandpaper to fit in the credit cart |500x281
Insert into the slot |500x281
Then make a right and left movement Make sure to sand all the contacts |500x193
Clean the residual dust with a compressed air ou isopropyl alcohol and be happy with your new cartridge slot
I have a question about the 12F629. I can program, and have available the 8 pin DIP version of the chip. I don't have a way to program a 8SOIC version. Do you know if this will work as well, assuming I bend the legs down so they can be soldered to the board?
Also, I have decided to use the microSD card. I assume no modification needs to be done to that like there is with the larger one? Also is there a place to purchase the nice clear LED spacer like you have instead? =) Thanks!
