gpop1:
study blink with out delay example and look at INPUT_PULLUP. you will need to change the code example to suit a input .
int ledPin = 13; // choose the pin for the LED
int inPin = 8; // choose the input pin (for a pushbutton)
byte forceOff = 7;
unsigned long previousMillis = 0;
unsigned long interval = 5000;
byte lightled = 0;
pinMode(ledPin, OUTPUT); // declare LED as output
pinMode(forceOff, INPUT_PULLUP); // declare LED as output
pinMode(inPin, INPUT_PULLUP); // declare pushbutton as input
byte val = digitalRead(inPin); // read input value
byte offbutton = digitalRead(forceOff); // read input value
if ((val == LOW) && (offbutton == HIGH)) {
lightled = 1;
if (offbutton == LOW) {
lightled = 0;
if (lightled == 1) {
if (currentMillis - previousMillis <= interval) {
digitalWrite(ledPin, HIGH); // turn LED ON
lightled = 0;
} else {//lighted not equal 1
digitalWrite(ledPin, LOW); // turn LED OFF
Most of those brackets are unnecessary and only serve to make the code harder to read.
It can be done more simply, too.
Since Brian's original version used active-high inputs, I've kept true to that, since I thought there might have been a good reason, but they're easily converted to active-low with input pullups and 'hard' resistors removed if necessary:-
// Connect pushbuttons between input pins and +5V. (Not 12V)
// and resistors from input pins to ground.
const byte pLED = 13; // LED on pin 13, active-high.
const byte inSig1 = 8; // First input signal on pin 8, active-high.
const byte inSig2 = 7; // Second input signal on pin 7, active-high.
unsigned long prevMillis; // Will hold millis() count.
pinMode(pLED, OUTPUT); // Make LED pin an output.
pinMode(inSig1, INPUT); // Make signal pins inputs.
pinMode(inSig2, INPUT); // " " " "
while (digitalRead(inSig1) == LOW){} // Wait for first signal.
digitalWrite(pLED, HIGH); // Got first signal - turn LED on.
prevMillis = millis(); // Save current 'millis' value.
while (millis() - prevMillis < 5000) // Keep LED on for 5 seconds.
if (digitalRead(inSig2) == HIGH) // Check if second signal has arrived and if so
break; // break out of 'while' loop.
digitalWrite(pLED, LOW); // Turn LED off.
while (digitalRead(inSig2) == HIGH){} // Wait for second signal to end before continuing.
Either way, now Brian's seen two different ways of doing it.
There's more than one way to skin a cat. (39, according to the robot in 'Lost in Space'.
And Brian, note that the second pushbutton/input signal is connected to pin 7.
