Hey guys, sry for being away such a long time. Thanks for your advice, I wont to giv esome feedback:
An aditional remote was a nogo for me. We hat remotes. And yes, we need more than one light setting.
I got it to work, but I can’t update my rduino anymore, because I destroyed my USB-TTL Adapter…
I want to post my code, its still not tested.
In the future, I want to integrate an XBee connection to controll the light via an self build remote conroll, which also controlls the home cinema.
#include <Bounce2.h> // See https://github.com/thomasfredericks/Bounce2/wiki
#include <EEPROM.h>
const int programs = 5; // Number of light programs
const int eeprom_start = 10; // First adress for EEPROM access. Max 1023 minus programs * 3
const unsigned long time_debounce = 100; // time needed for debounce the push button
const unsigned long time_setup = 5000; // time needed for press push button to enter setup-mode
* Just some variables for manipulating the delay between
* two brightness steps in setup-mode
const int delay_faktor = 10; // delay_faktor * (delay_minuend - i / delay_divisor)
const int delay_minuend = 50; //
const float delay_divisor = 2.0; //
* Pin-Configuration:
* Important to use pin 3 and 11. In setup, the neccessary CPU registers
* for phase correct PWM were set for these 2 pins. For details: https://www.arduino.cc/en/Tutorial/SecretsOfArduinoPWM
const int input = 12; // Input from the optocoupler
const int SpotRelaisPin = 8; // Controll output to 230V AC relay for turning LED spots on/off
const int transformer = 7; // Controll output to 230V AC relay for turning LED-stripe transformer on/off
const int LEDchannel1 = 3; // First channel of LED stripe
const int LEDchannel2 = 11; // Second channel of LED stripe
/* byte LED[(programs) * 3];
* Array that contains the brightness-values for all LED at all program states
* Structure:
* Program | LED channel 1 | LED channel 2 | LED Spots
* 0 | 0 1 2
* 1 | 3 4 5
* 2 | 6 7 8
* n | (3 * n) (3 * n + 1) (3 * n + 2)
* Values in table-content above represent the index of the array.
byte program = 0; // counter for active light program
unsigned long time_pushed = 0; // Point of time, when push button was closed last time
unsigned long time_released = 0; // Point of time, whan push button was opened last time
/* const unsigned long max_long = ~((unsigned long)0);
* stores the highest possible value of millis() before it overflows.
* Max value is 2^32 -1 bit (4,294,967,295).
* See https://www.arduino.cc/reference/en/language/functions/time/millis/
* This constant is used to check variables for reching the limit of
* unsigned long and start routines that prevent logic errors.
Bounce deb_input = Bounce();
deb_input.interval(time_debounce);
pinMode(input, INPUT); //-------------
pinMode(SpotRelaisPin, OUTPUT);
pinMode(transformer, OUTPUT); // Set all needed Pins to In or out
pinMode(LEDchannel1, OUTPUT);
pinMode(LEDchannel2, OUTPUT); //-------------
deb_input.attach(input);
* The following two lines will preset the registers in Atmega 328 to
* phase correct PWM at pins 3 and 11.
* Just modifying OCR2A (0-255) will configure pin 3
* Just modifying OCR2B (0-255) will configure pin 11
* For details: https://www.arduino.cc/en/Tutorial/SecretsOfArduinoPWM
TCCR2A = _BV(COM2A1) | _BV(COM2B1) | _BV(WGM20); // Initialising of phase correct PWM
TCCR2B = _BV(CS22); // for pins 3 and 11
digitalWrite(transformer, HIGH); // Make sure that both channels to the relay are HIGH
digitalWrite(SpotRelaisPin, HIGH); // The relay will switch, if the output is LOW
for(int i = 0; i < (programs * 3); i++) // Read the full program from the EEPROM. This prevents from
LED[i] = EEPROM.read(eeprom_start + i); // loosing configuration bye power loss (e.g. blackput)
/* blink_sequenz
* int n - number of iterations
* Just blink that often, which LED you are going to program:
* 1, 2 or 3.
void blink_sequenz(int n)
for (int i = 0; i < n; i++)
if (i != 0) delay(1500);
LED[(program * 3) + 0] = 255;
LED[(program * 3) + 1] = 255;
LED[(program * 3) + 2] = 1;
set_led();
delay(1500);
LED[(program * 3) + 0] = 0;
LED[(program * 3) + 1] = 0;
LED[(program * 3) + 2] = 0;
set_led();
if (i == n) delay(1500);
* save_program
* Stores the LED brightnesses of actual program to the EEPROM
* via EEPROM.uptdate
void save_program()
for(int i = program * 3; i < program * 3 + 3; i++)
EEPROM.update(eeprom_start + i, LED[i]);
* set_led();
* The function wich set all the outputs and manipulates the CPU-PWM registers.
* It reads the actual program and actual brightnes values from
* LED[program+[1,2,3]]
void set_led()
if(program == 0){
return ;
if(LED[(program * 3) + 2] > 0)
digitalWrite(SpotRelaisPin, LOW);
if(LED[(program * 3) + 0] > 0 || LED[(program * 3) + 1] > 0)
digitalWrite(transformer, LOW);
OCR2A = LED[(program * 3) + 0];
OCR2B = LED[(program * 3) + 1];
* int inputdelay(unsigned long wait)
* Waitung for wait milliseconds for any input
* If an input is recognized, the function aborts with return 1
* before teh tim eis over.
* If no input occurs during waitung time, function returns 0.
unsigned long now = millis();
* This if is to prevent logical errors if millis() almost overflows.
* It just delays the execution of the sketch to wait for the overflow
* before continue the sketch
if(max_long - wait < now)
delay(wait + 2);
now = millis();
while(now + wait <= millis())
deb_input.update();
if (deb_input.rose())
while(!deb_input.fell())
delay(5);
deb_input.update();
return 1;
return 0;
* int pwm_setup(int set_temp)
* This function just increase (0 to 250) and decrease (250 - 0)
* the brightness of one LED-stripe and wait for an acknowledge (input) of some brightness
* via inputdelay().
* It runs infinite till some input is recognized via inputdelay() and returns always 1.
while(1)
for (int i = 0; i < 26; i++)
LED[(program*3)+set_temp] = i * 10;
set_led();
if(inputdelay(delay_faktor * (delay_minuend - i / delay_divisor)))
return 1;
for (int i = 25; i == 0; i--)
set_led();
return 1;
* void setup_led()
* This function manages the call of other functions in order to
* change the actual LED program.
void setup_led()
int set = 0;
while(set < 2)
blink_sequenz(set+1);
set += pwm_setup(set);
while(set < 3)
LED[(program*3)+set] = !LED[(program*3)+set];
set_led();
if(inputdelay(1500))
set++;
save_program();
* void loop()
* Main function of all arduino sketches.
* It checks the input continuously and increasy program counter by 1 if
* Push button is pushed, released and waited for end of debounce time.
* If button is pushed and hold for time_setup milliseconds, setup_led() will
* edit the actual program.
int change;
if(max_long - (time_setup + 500) <= millis())
delay(time_setup + 1000);
change = deb_input.update();
time_pushed = millis();
if (deb_input.fell())
if(program < programs - 1)
program++;
program = 0;
set_led();
if (millis() - time_pushed >= time_setup && !change)
setup_led();
My wife loves the new lamp
