room thermostat to power up arduino
Hi
I should run arduino with more room thermostats. I should start more valve pumps and a gas water heater. The problem is I found everything with a push switch and I would need a thermostatic relay that has when the constant signal goes on and when and when the thermostat goes off it just interrupts it. Please help me resolve this issue.
bpanco: Hi
Since you posted in the programming section, what have you tried and what did the code do?
Paul
