Rosserial with arduino zero
Hi
I have an arduino zero, connected to native port, Arduino IDE 1.8.7, Ubuntu 18.04 and ROS melodic.
I did the rossserial arduino tutorial Hello World, to publish something to a ros topic. link text
My commands: 1.) roscore
separate terminal 2.) rosrun rosserial_python serial_node.py _port:=/dev/ttyACM0 _baud:=57600
The command window shows this: If think I have tried nearly everything. deinstall and install it, switched the computer off and on, tried with multiple baudrates (it is not hardcode in the .ino file, since I use the file form the tutorial, checked the usb port, tried commands, #define USE_USBCON, ros::spinOnce(), tried to set the baudrate in the .ino file: nodehande.getHardware()->setBaud(57600);
Nothing works and more surprisingly if I do the same procedure with an Arduino Uno it works. They should have the same architecture?
Does someone know where the mistake could be?
Thanks
You could ask ROS for assistance/debugging.
