Sorry.
I connected the click function in a button matrix, work fine.
The rotary part, other three connections: the middle one to GND, the DT to #7 and CLK to #8.
I used SimHub to program the sketch:
#ifndef __SHROTARYENCODER_H__
#define __SHROTARYENCODER_H__
#include <Arduino.h>
#include "SHFastIO.h"
#include "SHDebouncer.h"
#define R_START 0x0
#define DIR_CW 0x10
#define DIR_CCW 0x20
// Full steps
#define FS_R_CW_FINAL 0x1
#define FS_R_CW_BEGIN 0x2
#define FS_R_CW_NEXT 0x3
#define FS_R_CCW_BEGIN 0x4
#define FS_R_CCW_FINAL 0x5
#define FS_R_CCW_NEXT 0x6
// Half steps
#define HS_R_CCW_BEGIN 0x1
#define HS_R_CW_BEGIN 0x2
#define HS_R_START_M 0x3
#define HS_R_CW_BEGIN_M 0x4
#define HS_R_CCW_BEGIN_M 0x5
static const unsigned char fullStepsTable[7][4] =
// 00 01 10 11
{R_START, FS_R_CW_BEGIN, FS_R_CCW_BEGIN, R_START}, // R_START
{FS_R_CW_NEXT, R_START, FS_R_CW_FINAL, R_START | DIR_CW}, // R_CW_FINAL
{FS_R_CW_NEXT, FS_R_CW_BEGIN, R_START, R_START}, // R_CW_BEGIN
{FS_R_CW_NEXT, FS_R_CW_BEGIN, FS_R_CW_FINAL, R_START}, // R_CW_NEXT
{FS_R_CCW_NEXT, R_START, FS_R_CCW_BEGIN, R_START}, // R_CCW_BEGIN
{FS_R_CCW_NEXT, FS_R_CCW_FINAL, R_START, R_START | DIR_CCW}, // R_CCW_FINAL
{FS_R_CCW_NEXT, FS_R_CCW_FINAL, FS_R_CCW_BEGIN, R_START} // R_CCW_NEXT
static const unsigned char halfStepsTable[][4] =
// 00 01 10 11
{HS_R_START_M, HS_R_CW_BEGIN, HS_R_CCW_BEGIN, R_START}, // R_START (00)
{HS_R_START_M | DIR_CCW, R_START, HS_R_CCW_BEGIN, R_START}, // R_CCW_BEGIN
{HS_R_START_M | DIR_CW, HS_R_CW_BEGIN, R_START, R_START}, // R_CW_BEGIN
{HS_R_START_M, HS_R_CCW_BEGIN_M, HS_R_CW_BEGIN_M, R_START}, // R_START_M (11)
{HS_R_START_M, HS_R_START_M, HS_R_CW_BEGIN_M, R_START | DIR_CW}, // R_CW_BEGIN_M
{HS_R_START_M, HS_R_CCW_BEGIN_M, HS_R_START_M, R_START | DIR_CCW} // R_CCW_BEGIN_M
typedef void(*SHRotaryEncoderPositionChanged) (int, int, byte);
class SHRotaryEncoder {
private:
FastDigitalPin outputA; // CLK
FastDigitalPin outputB; // DT
FastDigitalPin button;
int counter = 0;
bool halfSteps = false;
uint8_t inputLastState;
uint8_t buttonState;
int buttonLastState;
unsigned long lastbuttonchange;
unsigned long positionLastChanged;
unsigned long directionLastChange = 255;
SHDebouncer buttonDebouncer;
uint8_t direction;
byte id;
SHRotaryEncoderPositionChanged positionChangedCallback;
public:
void begin(uint8_t outputAPin, uint8_t outputBPin, int buttonPin, bool reverse, bool enablePullup, byte encoderid, bool half, SHRotaryEncoderPositionChanged changedcallback) {
halfSteps = half;
buttonDebouncer.begin(50);
outputA.begin((!reverse) ? outputAPin : outputBPin);
outputB.begin((!reverse) ? outputBPin : outputAPin);
pinMode(outputAPin, enablePullup ? INPUT_PULLUP : INPUT);
pinMode(outputBPin, enablePullup ? INPUT_PULLUP : INPUT);
button.begin(buttonPin);
if (buttonPin > 0) {
pinMode(buttonPin, enablePullup ? INPUT_PULLUP : INPUT);
id = encoderid;
inputLastState = 0;
buttonLastState = button.digitalRead();
positionChangedCallback = changedcallback;
uint8_t getDirection(uint8_t delay, unsigned long referenceTime) {
if (directionLastChange != 255 && (referenceTime - positionLastChanged) < delay) {
return directionLastChange;
return 255;
uint8_t getPressed() {
return button.isValid() && !buttonLastState;
void read() {
if (!halfSteps)
inputLastState = fullStepsTable[inputLastState & 0xf][(outputB.digitalRead() << 1) | outputA.digitalRead()];
else {
inputLastState = halfStepsTable[inputLastState & 0xf][(outputB.digitalRead() << 1) | outputA.digitalRead()];
direction = (inputLastState & 0x30);
if (direction == DIR_CCW) {
counter++;
positionChangedCallback(id, counter, 0);
positionLastChanged = millis();
directionLastChange = 0;
else if (direction == DIR_CW) {
counter--;
positionChangedCallback(id, counter, 1);
directionLastChange = 1;
if (button.isValid()) {
buttonState = button.digitalRead();
if (buttonState != buttonLastState) {
if (buttonDebouncer.Debounce()) {
positionChangedCallback(id, counter, buttonState == HIGH ? 2 : 3);
buttonLastState = buttonState;
#endif
