rotary dail
hello i have a question
i have a rotary dail
and i use this to read it http://www.instructables.com/id/Interface-a-rotary-phone-dial-to-an-Arduino/
but now comes the problem i need to save 9 numbers in a variable and i cant seem to find out how to do this
i need this for an arduino phone i am building
in the end i have to dail +31 548 51**** (land city home)
can somone help me on this
rotary dail
Something to do with the Irish parliament on a turntable?
i dont get the joke ityped correctly right
or you just troll?
Yes, I’m just a troll, and no your typing is not good.
sorry i didnt ment to be harsh i am just realy dutch
Do some research on arrays.
somthing like
anArray[] = { var1,var2,var3 };
does that work?
if so
then i dont know how i can count 9 diverent variables
char anArray[9];gives you an array of 9 char variables from anArray[0] to anArray[8]
anArray[0] = '3';
anArray[1] = '5';
puts characters into the first and second positions in the array and so on.
for (int x = 0; x< 9; x++)
  Serial.println(anArray[x]);
prints each of the elements of the array in turn.
mmm that will not be suficent
i need to sent the array as one complete number
i found this script it seems to store the complete number in one array
but i cant seem to print that
You're not making a great deal of sense. Send an array as a single number? You mean like a 19 decimal digit 64 bit number? Or as the ASCII representation of an arbitrary length number? You found what script?
i want to store single numbers as one giant aray
like i said i am dailing 1-2-3
arduino gives me 1 2 3
and i want it as 123
and then send it of to a gsm module and have it called this works but is verry verry crude
int needToPrint = 0;
int count;
// mine
const int try_it = 3;
const int in_from_dial = 2;
int test;
int buttonState = 0;         // variable for reading the pushbutton status
int firstnum = 0;
char played = 'N';
// end mine
int lastState = LOW;
int trueState = LOW;
long lastStateChangeTime = 0;
int cleared = 0;
// constants
int dialHasFinishedRotatingAfterMs = 100;
int debounceDelay = 10;
// strings
String newstring;
pinMode(in_from_dial, INPUT);  // 2
digitalWrite(in_from_dial, HIGH);
pinMode(try_it, INPUT);  // 3
pinMode(13, OUTPUT);    // 12
void loop(){
  digitalWrite(13, HIGH);   // set the LED on
user will dial numbers until they hit the "try it" buttonb
so need to create string until button is pressed
// read the state of the tryit button
  buttonState = digitalRead(try_it);
// try_it = HIGH;
if (buttonState == LOW)   {
int reading = digitalRead(in_from_dial);
if ((millis() - lastStateChangeTime) > dialHasFinishedRotatingAfterMs) {
// the dial isn't being dialed, or has just finished being dialed.
if (needToPrint) {
// if it's only just finished being dialed, we need to send the number down the serial
// line and reset the count. We mod the count by 10 because '0' will send 10 pulses.
  Serial.println(count % 10, DEC);
// now need to add the count to the test string and then test it against the
// required string to get a hit
newstring.concat(count);
Serial.println(newstring);
needToPrint = 0;
count = 0;
cleared = 0;
if (reading != lastState) {
lastStateChangeTime = millis();
if ((millis() - lastStateChangeTime) > debounceDelay) {
// debounce - this happens once it's stablized
if (reading != trueState) {
// this means that the switch has either just gone from closed->open or vice versa.
trueState = reading;
if (trueState == HIGH) {
// increment the count of pulses if it's gone high.
count++;
needToPrint = 1; // we'll need to print this number (once the dial has finished rotating)
lastState = reading;
// now user wants to test his dialing
played = 'N';
//   Serial.println(newstring);
  test_it();
   newstring = "";
// --------------------- my functions -------------------------
// test the string
void test_it()
newstring = "";
loop();
// end of loop
So, don't use "println"
void test_it()
newstring = "";
loop();
See recursion
yes but how does that work on the gsm module
it does not
the gsm module needs a full number
mySerial.println("ATD + +31611******;");//dial the number (this is in my call script)
I think you need to slow down, work through some basic examples, and start looking at your code after using the auto-format tool. You're misunderstanding some very basic programming constructs.
i have run trough all beginner courses
but non helps me in the way i want
OK, you need to point out the beginner course that suggested that recursion on a micro controller is a good idea, 'cos I'm going round to the author's house and I'm going to be jolly unpleasant to him.
please do come by if you want some coffie
i also found it out
how to dail-call and output
i am hooking up the gprs shield as we speak
and after testing it sends the corect caracter set
but it does not call
after adding a bit of line it suddenly works
onwards it should be not so hard anymore
#include <SoftwareSerial.h>
#include <String.h>
SoftwareSerial mySerial(7, 8);
int count;
// mine
int test;
int firstnum = 0;
char played = 'N';
// end mine
int cleared = 0;
// constants
// strings
String newstring;
  mySerial.begin(19200);               // the GPRS baud rate
// try_it = HIGH;
if (needToPrint) {
newstring.concat(count % 10);
Serial.println("ATD + +31" + newstring + ";");
needToPrint = 0;
count = 0;
cleared = 0;
count++;
played = 'N';
  test_it();
   newstring = "";
 void test_it()
  mySerial.println("ATD + +31" + newstring + ";");//dial the number
delay(10000);
mySerial.println("ATH");
newstring = "";
loop();
void ShowSerialData()
  while(mySerial.available()!=0)
    Serial.write(mySerial.read());
sorry that i am such an pain in the ass somtimes
my learning proses involves learning from other people's work (why would we reinvent the wheel)
and that makes me a dick somtimes
the script i fabricated consists of 3 or 4 scripts made into one working (but crappy whole)
It's dial not dail and it's process not proses. Just helping your English spelling. ;)
You can't have "run through" even a few beginner courses if you don't understand a char array.
// this is an array of char. It is NULL permnated (the \0)
// make it big enough to hold one char more the largest number you will dial
// This one will hold 14 chars plus the NULL, so it's size is 15. You can also declare it as
//  char number[15];
// If you do, then you have to fill it and NULL terminate it with your code
char number[] = "+31 345 123456\0";
  Serial.begin(115200);  // chage this baud rate to suit
  Serial.print("ATDT ");
  Serial.println(number);
Copy this code, and paste it into your IDE. Compile/upload, the run the Serial Monitor. You should have listened to UKHeliBb.
Don't try to do too much at once. Start with putting numbers into a char array, thenwrite the code to send to the phone, and so on.
