hallo,
I have a old phone with rotary dial and a circuit board from a new one.
i tested manually applying a pulse to the correct numbers on the new board and it works
I'm trying to make a counter that only counts the number of pulses when the enable switch has been triggered and resets when the enable is low again.
i tried using if statements but it seems to be the wrong approach...
the counter counts even if the enable isn't high
after that i would use 7 output to make the necessary rows and columns
