rotary encoder and flex
I'm using xbee and its shield in arduino mega with 2 encoders and 2 flexs.. i tried to send code using map but it didn't work .. please help!!!!!
Code?
transmitter
#define encoder0PinA 2
#define encoder0PinB 3
#define encoder0PinC 18
#define encoder0PinD 19
int finger = A0;
int finger1 = A1;
int x=0;
int y=0;
volatile unsigned int encoder0Pos = 0;
volatile unsigned int encoder0Pos1 = 0;
Serial.begin (9600);
pinMode(encoder0PinA, INPUT);
pinMode(encoder0PinB, INPUT);
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(1, doEncoderB, CHANGE);
// encoder pin on interrupt 1 (pin 3)
pinMode(encoder0PinC, INPUT);
pinMode(encoder0PinD, INPUT);
attachInterrupt(4, doEncoderC, CHANGE);
attachInterrupt(5, doEncoderD, CHANGE);
void loop(){
  int q = analogRead(A0);
 int w = analogRead(A1);
 if(q){
  int val = map(q, 400, 600, 30, 67);
  // el ar2am elly hatetbe3et ma2soma 3ala 10 ^^^^^^^
      val = constrain(val, 30, 67);
  if((val >= 30) && (val <= 67)){
  Serial.write(val);
  delay(40);
if(w){
int val_1 = map(w, 400, 600, 68, 170);
    val_1 = constrain(val_1, 68, 170);
  if((val_1 >= 68) && (val_1 <=170)){
  Serial.write(val_1);
  delay(40);
void doEncoderA(){
if (digitalRead(encoder0PinA) == HIGH) {
// found a low-to-high on channel A
if (digitalRead(encoder0PinB) == LOW) {
// check channel B to see which way encoder is turning
encoder0Pos = encoder0Pos + 1; // CW
else {
encoder0Pos = encoder0Pos - 1; // CCW
else // found a high-to-low on channel A
if (digitalRead(encoder0PinB) == HIGH) {
else {
//Serial.print(encoder0Pos);
y = map(encoder0Pos,0,1100,380,560); //was >> y = map(encoder0Pos,0,31,0,32)
if( (y >= 0) && ( y <= 180) )
Serial.write(y);
void doEncoderB(){
// found a low-to-high on channel B
// check channel A to see which way
// encoder is turning
else {
if (digitalRead(encoder0PinA) == LOW) {
else {
Serial.write(y);
void doEncoderC(){
if (digitalRead(encoder0PinC) == HIGH) {
if (digitalRead(encoder0PinD) == LOW) {
encoder0Pos1 = encoder0Pos1 + 1; // CW
else {
encoder0Pos1 = encoder0Pos1 - 1; // CCW
if (digitalRead(encoder0PinD) == HIGH) {
else {
x = map(encoder0Pos1,0,1100,190,370);  //was >> x = map(encoder0Pos1,0,31,66,99)
if( (x >= 190) && ( x <= 370) )
Serial.write(x);
void doEncoderD(){
else {
if (digitalRead(encoder0PinC) == LOW) {
else {
Serial.write(x);
receiver
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
int x=0;
int y=0;
servo1.attach(9); //Servo 1 is on Pin 9
servo2.attach(10); //Servo 2 is on Pin 10
servo3.attach(11); //Servo 3 is on Pin 11
servo4.attach(12); //Servo 4 is on Pin 12
servo1.write(0); //position servo at 0 initially
servo2.write(0); //position servo at 0 initially
servo3.write(0); //position servo at 0 initially
servo4.write(0); //position servo at 0 initially
void loop(){
while(Serial.available() == 0);
  int encoder0Pos = Serial.read();
  if( (encoder0Pos>=190) && (encoder0Pos<=370) )
   x=map(encoder0Pos,190,370,0,180);
if( (x >= 0) && ( x <= 180) ){
servo2.write(x*5.5);
if( (encoder0Pos >= 0) && (encoder0Pos <= 32) )
y=map(encoder0Pos,380,560,0,180);
if( (y >= 0) && ( y <= 180) ){
servo1.write(y);
 int out=0;
 int out1=0;
  int data = Serial.read() ;
if((data >= 30) && (data <= 67)){
  int pos = map(data*10, 300, 670, 180, 0);
    int  pos1 = constrain(pos, 0, 90);// MOHEM GEDDAN
  if(pos < 90){
  out=pos1*1.75;
  else{
  int  pos2 = constrain(pos, 90, 180);// MOHEM GEDDAN
  if(pos > 90){
  out=pos2*1.75;
     servo3.write(out/2);}
  delay(10);
  //Serial.println(out);
  if((data >= 68) && (data <= 170)){
  int pos = map(data*10, 680, 1700, 180, 0);
  if(pos < 90){
  out1=pos1;
  else{
  if(pos >= 90){
  out1=pos2;
 servo4.write(out1);
  delay(10);
this for 2 encoders and 2 flex
Aaaaand what's the problem?
 if(q){
The analogRead() function returns a value between 0 and 1023. Using that value as a boolean does not make sense.
What if q is not in the range 400 to 600?
Clearly, you don’t understand what constrain() does.
I gave up reading at this point:
Put every { on a line by itself.
Put each and every } on a line by itself.
Use Tools + Auto Format to fix that horrid indenting.
Post again.
You seem to be sending random, unidentified values, and expecting the receiver to know what you sent. That will NEVER work.
non of encoders or flex working ... both of encoders and flex working alone but when i but both of them together in the same code they not work
hossamm92:
You'll need to explain what "they not work" means. You are doing Serial.write() in an interrupt service routine. That is a REALLY bad idea.
PaulS:
i dont know what to do ... i'm new in using arduino
Post again.
[/quote]
this after auto-format
transmitter
int finger = A0;
int finger1 = A1;
int x = 0;
int y = 0;
 if (q) {
   if ((val >= 30) && (val <= 67)) {
     Serial.write(val);
     delay(40);
 if (w) {
   if ((val_1 >= 68) && (val_1 <= 170)) {
     delay(40);
void doEncoderA() {
   else {
   else {
 y = map(encoder0Pos, 0, 1100, 380, 560); //was >> y = map(encoder0Pos,0,31,0,32)
 if ( (y >= 0) && ( y <= 180) )
   Serial.write(y);
void doEncoderB() {
   else {
   else {
   Serial.write(y);
void doEncoderC() {
   else {
   else {
 x = map(encoder0Pos1, 0, 1100, 190, 370); //was >> x = map(encoder0Pos1,0,31,66,99)
 if ( (x >= 190) && ( x <= 370) )
   Serial.write(x);
void doEncoderD() {
   else {
   else {
   Serial.write(x);
Post again.
receiver
#include <Servo.h>
Servo servo1;
Servo servo2;
Servo servo3;
Servo servo4;
int x = 0;
int y = 0;
 while (Serial.available() == 0);
 if ( (encoder0Pos >= 190) && (encoder0Pos <= 370) )
   x = map(encoder0Pos, 190, 370, 0, 180);
   if ( (x >= 0) && ( x <= 180) ) {
     servo2.write(x * 5.5);
 if ( (encoder0Pos >= 0) && (encoder0Pos <= 32) )
   y = map(encoder0Pos, 380, 560, 0, 180);
   if ( (y >= 0) && ( y <= 180) ) {
     servo1.write(y);
 int out = 0;
 int out1 = 0;
 if ((data >= 30) && (data <= 67)) {
   int pos = map(data * 10, 300, 670, 180, 0);
   if (pos < 90) {
     out = pos1 * 1.75;
   else {
     if (pos > 90) {
       out = pos2 * 1.75;
   servo3.write(out / 2);
 delay(10);
 if ((data >= 68) && (data <= 170)) {
   int pos = map(data * 10, 680, 1700, 180, 0);
   if (pos < 90) {
     out1 = pos1;
   else {
     if (pos >= 90) {
       out1 = pos2;
   servo4.write(out1);
 delay(10);
PaulS:
if(q){
That is a perfectly acceptable and very common way to test that a value is not zero. I don't know that this is what the OP intended, but it is very common practice for those of us who actually write code.
Delta_G:
So where is the problem in the code ?
I actually write code for a living, and I NEVER do that.
if(i != 0)
is not that difficult to type, and makes it CRYSTAL CLEAR what is being compared to what.
PaulS:
if(i != 0)
The language specification makes it crystal clear what that is supposed to do.
