I am using the very nice rotary encoder code using no debouncing from pinteric. It works fine until I uncomment the Distance_Sensor.read(); aftr which I just stops working.
I have tried using different interrups on a Mega but am now at a loss as to what the problem is.
Any guidance greatly appreciated.
[code]
Reading distance from the laser based VL53L1X
By: kaloha
CQRobot
VL53L1X Distance Sensor from CQRobot: http://www.cqrobot.wiki/index.php/VL53L1X_Distance_Sensor
This example demonstrates how to read the distance in short mode(up to 1.3m) and the measurement status.
#include <Wire.h>
#include "VL53L1X.h"
VL53L1X Distance_Sensor;
// Rotary encoder pins
//const byte PIN_A = 2;
//const byte PIN_B = 3;
const byte PIN_A = 2; //2 for Uno; 2 or 18 for Mega
const byte PIN_B = 3; //3 for Uno; 2 or 19 for Meg
// A turn counter for the rotary encoder (negative = anti-clockwise)
int rotationCounter = 200;
int counterLast = 0;
// Flag from interrupt routine (moved=true)
volatile bool rotaryEncoder = false;
// Rotary encoder has moved (interrupt tells us) but what happened?
// See https://www.pinteric.com/rotary.html
int8_t checkRotaryEncoder() {
// Reset the flag that brought us here (from ISR)
static uint8_t lrmem = 3;
static int lrsum = 0;
static int8_t TRANS[] = {0, -1, 1, 14, 1, 0, 14, -1, -1, 14, 0, 1, 14, 1, -1, 0};
// Read BOTH pin states to deterimine validity of rotation (ie not just switch bounce)
int8_t l = digitalRead(PIN_A);
int8_t r = digitalRead(PIN_B);
Serial.print(l);
Serial.print(r);
// Move previous value 2 bits to the left and add in our new values
lrmem = ((lrmem & 0x03) << 2) + (2 * l) + r;
Serial.print("\tlrmem : ");
Serial.print(lrmem);
// Convert the bit pattern to a movement indicator (14 = impossible, ie switch bounce)
lrsum += TRANS[lrmem];
Serial.print("\tlrsum : ");
Serial.print(lrsum);
/* encoder not in the neutral (detent) state */
if (lrsum % 4 != 0) {
Serial.println("\tNOT");
return 0;
/* encoder in the neutral state - clockwise rotation*/
if (lrsum == 4) {
Serial.println("\tCW ");
lrsum = 0;
return 1;
/* encoder in the neutral state - anti-clockwise rotation*/
if (lrsum == -4) {
Serial.println("\tCCW ");
lrsum = 0;
return -1;
// An impossible rotation has been detected - ignore the movement
lrsum = 0;
Serial.println("\tIMP ");
return 0;
// Interrupt routine just sets a flag when rotation is detected
void rotary() {
rotaryEncoder = true;
Wire.begin();
Wire.setClock(400000); // originally 400 kHz I2C
Serial.println("VL53L1X Distance Sensor tests in short distance mode(up to 1.3m).");
Distance_Sensor.setTimeout(500);
if (!Distance_Sensor.init())
Serial.println("Failed to initialize VL53L1X Distance_Sensor!");
while (1);
// Use long distance mode and allow up to 50000 us (50 ms) for a measurement.
// You can change these settings to adjust the performance of the sensor, but
// the minimum timing budget is 20 ms for short distance mode
Distance_Sensor.setDistanceMode(VL53L1X::Short);
Distance_Sensor.setMeasurementTimingBudget(25000);
// Start continuous readings at a rate of one measurement every 50 ms (the
// inter-measurement period). This period should be at least as long as the
// timing budget.
Distance_Sensor.startContinuous(25);
// The module already has pullup resistors on board
pinMode(PIN_A, INPUT);
pinMode(PIN_B, INPUT);
// We need to monitor both pins, rising and falling for all states
attachInterrupt(digitalPinToInterrupt(PIN_A), rotary, CHANGE);
attachInterrupt(digitalPinToInterrupt(PIN_B), rotary, CHANGE);
//!!!!!!! Uncomment the following and the rotary encoder stops working !!!!!!
// Distance_Sensor.read();
// Has rotary encoder moved?
if (rotaryEncoder == true) {
// Get the movement (if valid)
int8_t rotationValue = checkRotaryEncoder();
rotationCounter += rotationValue;
if (rotationCounter != counterLast) {
counterLast = rotationCounter;
Serial.print("\nEncoder : ");
Serial.print(rotationCounter);
Serial.print("\tDistance : ");
Serial.println(Distance_Sensor.ranging_data.range_mm);
[/code]
