Rotary encoder for high resolution
Can someone tell me if I can use a ky 040 encoder to change the duty cycle at a resolution of 0.1%. I remembered someone using 2 pwm pins to increase the resolution for up to 16 bits.I only need a 10 bit resolution with a changing frequency between 200Hz and 1kHZ
Resolution of the PWM, frequency of the PWM, duty cycle of the PWM.
Although it is true that I can convert any given value I have to somehow count the impulses and interpret them to match so that with each impulse the duty cycle will change by 0.1%
