I'm working on a project for a dummy load and I'm using a rotary encoder to adjust the size of the load. Here's a section of my code:
#include <SoftwareSerial.h>
#include <serLCD.h>
serLCD lcd(4);
enum PinAssignments {
encoderPinA = 2, // rigth
encoderPinB = 3, // left
volatile int encoderPos[] = {0,0,0,0}; // a counter for the dial
int lastReportedPos[] = {1,1,1}; // change management
static boolean rotating=false; // debounce management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
pinMode(7, INPUT);
// turn on pullup resistors
digitalWrite(encoderPinA, HIGH);
digitalWrite(encoderPinB, HIGH);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, doEncoderB, CHANGE);
Encoder();
Power();
int Power()
int P;
P=encoderPos[0];
lcd.setCursor(1,1);
lcd.print(" Power ");
lcd.setCursor(2,1);
lcd.print("P = ");
lcd.setCursor(2,5);
lcd.print(P);
lcd.print(" ");
int Encoder()
rotating = true; // reset the debouncer
if (lastReportedPos[0] != encoderPos[0]) {
if(encoderPos[0]<0)encoderPos[0]=0;
lastReportedPos[0] = encoderPos[0];
void doEncoderA(){
// debounce
if ( rotating ) delay (10); // wait a little until the bouncing is done
// Test transition, did things really change?
if( digitalRead(encoderPinA) != A_set ) { // debounce once more
A_set = !A_set;
// adjust counter + if A leads B
if ( A_set && !B_set )
encoderPos[0]++;
rotating = false; // no more debouncing until loop() hits again
// Interrupt on B changing state, same as A above
void doEncoderB(){
if( digitalRead(encoderPinB) != B_set ) {
B_set = !B_set;
// adjust counter - 1 if B leads A
if( B_set && !A_set )
encoderPos[0]--;
rotating = false;
The problem I keep running into is I will turn the knob one click to increment by one and sometimes it will work. Other times though, when I turn it one click it will increment by 4 or 3 OR it will decrement, sometimes by one, other times by two or three.
I'm not very familiar with rotary encoders so I'm struggling to debug the issue, I thought by using interrupts it would solve this problem for me but it hasn't.
If it helps, the encoder I'm using is the RGB Sparkfun encoder:Rotary Encoder - Illuminated (RGB) - COM-15141 - SparkFun Electronics
If someone can help me figure out what the problem is, I'd greatly appreciate it.
