Rotary Encoder help
Hi All,
I am building Controller Unit for controlling my Rover.
I was thinking of using a Rotary Encoder to control the speed, but cant figure out how to do it?
I can count the steps using this code but how can i use it to scroll through the values 85, 170 and 255?
byte A = 2;        // One quadrature pin
byte B = 3;        // the other quadrature pin
volatile int Rotor = 0;
    // set DIO pins
    pinMode(Blinker, OUTPUT);
    pinMode(A, INPUT);
    pinMode(B, INPUT);
    // Turn on pullup resistors
    digitalWrite(A, HIGH);
    digitalWrite(B, HIGH);
    // Attach interrupt to pin A
    attachInterrupt(0, UpdateRotation, FALLING);
    // Use serial port to keep user informed of rotation
void UpdateRotation() {
    if (digitalRead(B)) {
        Rotor++;
        Rotor--;
Thanks in Advance
Were you able to glean any info from here? http://www.arduino.cc/playground/Main/RotaryEncoders
