Rotary encoder interrupt and setting limits to position
I'm trying to program a rotary encoder on a interrupt to go from 1 to 100 and when they turn it further past those number it just sets the position to either one respectively. When i code it and turn the encoder past those number and then go to turn it back it does start immediately counting up or down from 1 or 100 but doesnt change until you turn it back the amount you over turned it.
I'm using a arduino nano and the rotary is connected to pins 2 and 3.
// InterruptRotator.ino - Example for the RotaryEncoder library.
// This class is implemented for use with the Arduino environment.
// Copyright (c) by Matthias Hertel, http://www.mathertel.de
// This work is licensed under a BSD 3-Clause License. See http://www.mathertel.de/License.aspx
// More information on: http://www.mathertel.de/Arduino
// This example checks the state of the rotary encoder using interrupts and in the loop() function.
// The current position and direction is printed on output when changed.
#include <Arduino.h>
#include <RotaryEncoder.h>
#define PIN_IN1 2
#define PIN_IN2 3
// A pointer to the dynamic created rotary encoder instance.
// This will be done in setup()
RotaryEncoder *encoder = nullptr;
void checkPosition(){encoder->tick();} // just call tick() to check the state.
  while (!Serial)
  Serial.println("InterruptRotator example for the RotaryEncoder library.");
  // setup the rotary encoder functionality
  // use TWO03 mode when PIN_IN1, PIN_IN2 signals are both LOW or HIGH in latch position.
  encoder = new RotaryEncoder(2, 3, RotaryEncoder::LatchMode::TWO03);
  // register interrupt routine
  attachInterrupt(digitalPinToInterrupt(2), checkPosition, CHANGE);
  attachInterrupt(digitalPinToInterrupt(3), checkPosition, CHANGE);
} // setup()
// Read the current position of the encoder and print out when changed.
  static int pos = 0;
  encoder->tick(); // just call tick() to check the state.
  int newPos = encoder->getPosition();
  if(newPos <0){newPos=1;}
  if(newPos >100){newPos=100;}
  if (pos != newPos) {
    Serial.print("pos:");
    Serial.print(newPos);
    Serial.print(" dir:");
    Serial.println((int)(encoder->getDirection()));
    pos = newPos;
  } // if
} // loop ()
You are constraining the 'newPos' variable but aren't telling the encoder object about it. Try this:
  int newPos = constrain(encoder->getPosition(), 1, 100);
  encoder->setPosition(newPos);
See This Example that comes as part of This Encoder Library.
