rotary encoder (not always the same question) on attiny
hello,
I m looking as a mad for a library to use a rotary encoder on an attiny84. this chip only has 1 external interrup. so i can t use the standard libraries. i tried ClickEncoder but it rely on TimerOne and on the t84 there are just to 2bit timer
any help would be very appreciated
ClickEncoder doesn't rely on TimerOne. It relies on you calling it with a fixed interval. TimerOne is just a easy way to do that. But any other methode (and/or library) will do.
aster94:
Perhaps you could use pinChange interrupts?
...R
septillion:
ok to be honest i didn't check well the library i just saw that it didn't compile and i wrote here hoping that someone had a simple solution
so:
#include <ClickEncoder.h>
#include <TimerOne.h>
ClickEncoder *encoder;
int16_t oldEncPos, encPos;
#define pinA 6
#define pinB 5
#define pinSw 4 //switch
void timerIsr() {
  encoder->service();
  pinMode(13, OUTPUT);
  encoder = new ClickEncoder(pinA, pinB, pinSw);
  Timer1.initialize(1000);
  Timer1.attachInterrupt(timerIsr);
  encoder->setAccelerationEnabled(1);
  Serial.print("Acceleration is ");
  Serial.println((encoder->getAccelerationEnabled()) ? "enabled" : "disabled");
  oldEncPos = -1;
  encPos += encoder->getValue();
  if (encPos != oldEncPos) {
    oldEncPos = encPos;
    Serial.print("Encoder Value: ");
    Serial.println(encPos);
  ClickEncoder::Button buttonState = encoder->getButton();
  if (buttonState != ClickEncoder::Open) {
    Serial.print("Button: ");
#define VERBOSECASE(label) case label: Serial.println(#label); break;
    switch (buttonState) {
        VERBOSECASE(ClickEncoder::Pressed);
        VERBOSECASE(ClickEncoder::Released)
        VERBOSECASE(ClickEncoder::Clicked)
      case ClickEncoder::DoubleClicked:
        Serial.println("DoubleClicked");
      case ClickEncoder::Held:
        digitalWrite(13, HIGH);
        delay(100);
  digitalWrite(13, LOW);
so from the .cpp looks like that timerOne just do this:
Timer1.initialize(1000); //set the period in microsecond to do "something"
Timer1.attachInterrupt(timerIsr); //call the isr that update the encoder status
Well i don't want to look lazy but could someone suggest me a timer interrupt library for an 8bit timer? i don't want to work with registers
Robin2:
...R
i wasn't able to find a good library to do it!
aster94:
Does it need a library?
...R
I m back on the project and yes even if for many of you it is simple i need a livrary to use rotary encoders on attiny so if anyone know one it would be appreciated
Maybe there is some registers with different name between m328p and attiny84 because the same code/lib i used on the nano is not working
What are you using the encoder for? Is it a manual control? Position or RPM sensing for a motor? You may not need interrupts if the pulse frequency is slow enough (use polling). What encoder are you using?
groundFungus:
Manual control for oled menu navigation, i didn t want to use the polling method since it would take more flash and i am on a tiny84
Post a link to the datasheet for the encoder you are using.
...R
it is the tipical rotary encoder found on a lot of web seller
it is with quadrature output i read:
//10, 0, 1, 11
//1, 0, 10, 11
for every step, depending on the direction
groundFungus:
it seems that you were right, i add my solution for a rotary encoder without library, with polling method for future readers:
#define pinA 8
#define pinB 9
#define pinSw 7
byte aPos = 0;
byte bPos = 0;
byte port, oldPort;
byte encPos = 0;
byte oldEncPos = 0;
#define debug
  pinMode(pinA, INPUT_PULLUP);
  pinMode(pinB, INPUT_PULLUP);
  pinMode(pinSw, INPUT_PULLUP);
  //Serial.begin(115200);
  while (encPos < 50) {
    encMove();
    if (oldEncPos != encPos) {
      //Serial.println(encPos);
    oldEncPos = encPos;
  if (!digitalRead(pinSw)) {
    //Serial.println("pressed");
void encMove() {
  port = PINB & 0x03;
  if (port != oldPort) {
    //Serial.print("port:\t"); Serial.println(port, BIN);
    //Serial.println();
    //10, 0, 1, 11
    //1, 0, 10, 11
    if (port == 0b10 && aPos) {
      //Serial.println("anticlockwise");
      encPos--;
      aPos = 0;
      bPos = 0;
    } else if (port == 0b10) {
      bPos = 1;
    if (port == 0b1 && bPos) {
      //Serial.println("clockwise");
      encPos++;
      aPos = 0;
      bPos = 0;
    } else if (port == 0b1) {
      aPos = 1;
  oldPort = port;
it works pretty well and it is 868 byte with arduino uno so not so much, I will try to use it in my main project in the next days
Any suggestion about how to reduce the size of the sketch would be helpful
Here is an example of how I read my encoders. A little over 400 bytes with all the serial print stuff removed.
const byte aPin = 5;
const byte bPin = 4;
long encoderCnt = 0;
  pinMode(aPin, INPUT_PULLUP);
  pinMode(bPin, INPUT_PULLUP);
  if (readEncoder()) // count changed?
    Serial.print("Encoder count =  ");
    Serial.println(encoderCnt);
boolean readEncoder()
  boolean newEncode = false;  // new count flag
  static boolean last_aState = 0;
  boolean aState = digitalRead(aPin);
  boolean bState = digitalRead(bPin);
  if (aState != last_aState)
    if (aState != bState)
      encoderCnt++;
      encoderCnt--;
      //Serial.println("counter clockwise");
    last_aState = aState;
    newEncode = true;
  return newEncode;
groundFungus:
      encoderCnt++;
      encoderCnt--;
    newEncode = true;
  return newEncode;
tested, you could decrease the memory usage with direct port manipulation but maybe you don't need it
anyway i think we have different encoder type, using your sketch i get 2 steps of resolution (i mean i can t go from 1 to 2, it will jump to 3)
i made it more simply and it still works:
#define pinA 8
#define pinB 9
#define pinSw 7
byte encPos = 0;
byte oldEncPos = 0;
byte port, oldPort;
  encMove();
  oldEncPos = encPos;
void encMove() {
  port = PINB & 0x03;
  //Serial.println();
  //10, 00, 01, 11
  //01, 00, 10, 11
  if (oldPort == 0b11 && port == 0b01) {
    encPos--;
  else if (oldPort == 0b11 && port == 0b10) {
    encPos++;
  oldPort = port;
