Rotary Encoder (partially) blocking I/O Button
Hello,
I'm using Rotary Encoder to switch on Light and set up the Brightness on UNO (YUN).
The Code have got 2 Parts: Switch ON/OFF and the Brightness SetUp with Interrupts.
Without the Brightness part of the Software, the I/O Switch is working fine.
When I add the Interrupts for the Brightness, the I/O Switch working only on every second Stop.
The Encoder, with 30 positions, I'm using is this one: http://www.conrad.at/ce/de/product/705538/Drehimpulsgeber-5-VDC-001-A-Schaltpositionen-30-360-DDM-Hopt-Schuler-427-021101AL001-IP50-zwischen-Achse-und-Gehae?ref=list
enum PinAssignments
  encoderPinA = 2,   // right (labeled DT on our decoder, yellow wire)
  encoderPinB = 3,   // left (labeled CLK on our decoder, green wire)
  //clearButton = 8  // switch (labeled SW on our decoder, orange wire)
volatile unsigned int encoderPos = 0;  // a counter for the dial
unsigned int lastReportedPos = 0;   // change management
static boolean rotating=false;      // debounce management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
the Setup
  pinMode(encoderPinA, INPUT_PULLUP); // new method of enabling pullups
  pinMode(encoderPinB, INPUT_PULLUP);
  //pinMode(clearButton, INPUT_PULLUP);
 // turn on pullup resistors (old method)
  //digitalWrite(encoderPinA, HIGH);
 // digitalWrite(encoderPinB, HIGH);
 // digitalWrite(clearButton, HIGH);
// encoder pin on interrupt 0 (pin 2)
  attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
  attachInterrupt(1, doEncoderB, CHANGE);
the Loop
 // read the state of the switch into a local variable:
  int reading = digitalRead(buttonPin);
  // check to see if you just pressed the button
  // (i.e. the input went from LOW to HIGH),  and you've waited
  // long enough since the last press to ignore any noise:
  // If the switch changed, due to noise or pressing:
  if (reading != lastButtonState)
    // reset the debouncing timer
    lastDebounceTime = millis();
  if ((millis() - lastDebounceTime) > debounceDelay) {
    // whatever the reading is at, it's been there for longer
    // than the debounce delay, so take it as the actual current state:
    // if the button state has changed:
    if (reading != buttonState) {
      buttonState = reading;
      // only toggle the LED if the new button state is HIGH
      if (buttonState == HIGH) {
        ledState = !ledState;
  // set the LED:
  digitalWrite(ledPin, ledState);
  // save the reading.  Next time through the loop,
  // it'll be the lastButtonState:
  lastButtonState = reading;
  //START Rotary Encoder
  rotating = true;  // reset the debouncer
  if (lastReportedPos != encoderPos) {
    Serial.print("Index:");
    Serial.println(encoderPos, DEC);
    lastReportedPos = encoderPos;
  /*if (digitalRead(clearButton) == LOW )  {
    encoderPos = 0;
// Interrupt on A changing state
void doEncoderA(){
  // debounce
  if ( rotating && ledState == HIGH) delay (1);  // wait a little until the bouncing is done
  // Test transition, did things really change?
  if( digitalRead(encoderPinA) != A_set ) {  // debounce once more
    A_set = !A_set;
    // adjust counter + if A leads B
    if ( A_set && !B_set && encoderPos < 240 && ledState == HIGH)
      encoderPos += 16;
    rotating = false;  // no more debouncing until loop() hits again
// Interrupt on B changing state, same as A above
void doEncoderB(){
  if( digitalRead(encoderPinB) != B_set ) {
    B_set = !B_set;
    //  adjust counter - 1 if B leads A
    if( B_set && !A_set && encoderPos > 0 && ledState == HIGH)
      encoderPos -= 16;
    rotating = false;
IMHO the Problem is in the SetUp part.
Does anybody have got an Idea what causes this problems?
Regards,
Richard
Yes, poorly written code causes most of the problems brought here. Poorly posted code is a close second. Post ALL of your code in ONE code block.
As well as what @PaulS says ...
Why are you debouncing the encoder?
Why have you a 1 millisec delay in a interrupt routine.
You should aim to run the whole interrupt routine in as few micro seconds as possible.
Your code would be much easier to understand if you put the switch read/debounce stuff into a function so you don't see the detail while reading the main part of the program.
...R
Thank You,
I deleted all Delays and it works now.
I'll try to revrite this code.
Regards,
Richard
