Rotary encoder problems
Hi
I have this SpinTrak http://www.ultimarc.com/SpinTrak.htm
With brown to +5v, white to ground, green pin 8, yellow pin 9.
I can't seem to get any sensible reading from it. I am using the code from the playground, looks like this:
int encoderPinOne = 8;
int encoderPinTwo = 9;
int encoderPos = 0;
  pinMode(encoderPinOne, INPUT);
  pinMode(encoderPinTwo, INPUT);
  // attach interrups
  PCattachInterrupt(8, doEncoderPinOne, CHANGE);
  PCattachInterrupt(9, doEncoderPinTwo, CHANGE);
  Serial.begin (9600);
void loop(){
  Serial.println(encoderPos);
void doEncoderPinOne(){
  int valOne = digitalRead(encoderPinOne);
  int valTwo = digitalRead(encoderPinTwo);
  // look for a low-to-high on channel A
  if (valOne == HIGH) {
    // check channel B to see which way encoder is turning
    if (valTwo == LOW) {
      encoderPos = encoderPos + 1;         // CW
      //Serial.println(1);
    else {
      encoderPos = encoderPos - 1;         // CCW
      //Serial.println(2);
  }else   // must be a high-to-low edge on channel A
    if (valTwo == HIGH) {
      //Serial.println(3);
    }else{
      //Serial.println(4);
  //Serial.println (encoder0Pos);//, DEC);
  // use for debugging - remember to comment out
void doEncoderPinTwo(){
  // look for a low-to-high on channel B
   // check channel A to see which way encoder is turning
      //Serial.println(5);
    else {
      //Serial.println(6);
  // Look for a high-to-low on channel B
  else {
    if (valOne == LOW) {
      //Serial.println(7);
    else {
      //Serial.println(8);
It is telling me the encoderPos is always zero. When I do the print serial statements within each function, I get back these messages
doEncoderPinOne shows 4 & 2 doEncoderPinTwo shows 5 & 7
2 = high, high 4 = high, low 5 = high, high 7 = low, low
If anyone has any ideas they would be really appreciated.
Thanks
