Hi, I want to toggle on/ off value using the step of rotary encoder. So that for one step ahead I can have ON and in the next step I can have OFF, and it will continue as i go ahead.
May I have any sample code to work on.
Here is the sample code:
const int encoderPinA = 2;
const int encoderPinB = 3;
const int ledPin = 13;
volatile int encoderPos = 0;
boolean ledState = LOW;
pinMode(encoderPinA, INPUT_PULLUP);
pinMode(encoderPinB, INPUT_PULLUP);
pinMode(ledPin, OUTPUT);
attachInterrupt(digitalPinToInterrupt(encoderPinA), updateEncoder, CHANGE);
// Other code here
void updateEncoder() {
int MSB = digitalRead(encoderPinA);
int LSB = digitalRead(encoderPinB);
int encoded = (MSB << 1) | LSB;
int sum = (encoderPos << 2) | encoded;
if (sum == 0b1101 || sum == 0b0100 || sum == 0b0010 || sum == 0b1011) encoderPos++;
if (sum == 0b1110 || sum == 0b0111 || sum == 0b0001 || sum == 0b1000) encoderPos--;
if (encoderPos % 4 == 0) { // Toggle on every 4 steps
ledState = !ledState;
digitalWrite(ledPin, ledState);
Keep it simple, you can use either output to toggle a port pin on your Arduino, then treat it like a push button (push on, push off). I am assuming you are using something like the KY-040 rotary encoder.
