I am currently trying to get my rotary encoder and lcd to work together. For now the aim is to have the LCD display the rotary count as i turn the rotary and when i push the button switch on LED on 13 for 1 second, and return the counter to 0.
When i upload the code below this is what happens:
1/ The "Index" shows up on the LCD but flickering very fast
2/ When I turn the rotary i can see the counter working but again flickering very fast
3/ When I press the rotary button "Index" stops flickering but the count is not shown, Led 13 lights up but does not go off after 1 second.
I would be grateful if anybody could guide where i am going wrong.
Thanks.
#include <LiquidCrystal.h>
LiquidCrystal lcd (12, 11, 8, 9, 6, 7);
enum PinAssignments {
encoderPinA = 3, // right (labeled DT on our decoder, yellow wire)
encoderPinB = 2, // left (labeled CLK on our decoder, green wire)
clearButton = A0 // switch (labeled SW on our decoder, orange wire)
volatile int encoderPos = 0; // a counter for the dial
int lastReportedPos = 1; // change management
static boolean rotating = false; // debounce management
int UIstate = 0; //User state management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
pinMode(encoderPinA, INPUT_PULLUP); // new method of enabling pullups
pinMode(encoderPinB, INPUT_PULLUP);
pinMode(clearButton, INPUT_PULLUP);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, doEncoderB, CHANGE);
lcd.begin(16, 2);
// Serial.begin(9600); // output
UserInterface();
navigateMenu();
void navigateMenu()
lcd.clear();
lcd.setCursor(0,0);
lcd.print("Index:");
switch (UIstate)
case 1:
digitalWrite(13, HIGH); //ENTER PART using LED on 13 for testing purposes
digitalWrite (13, LOW);
case 2:
lcd.print(encoderPos, DEC); //CW ROTATION print counter
case 3:
lcd.print(encoderPos, DEC); //CCW ROTATION print counter
void UserInterface()
rotating = true; // reset the debouncer
if (lastReportedPos != encoderPos)
lastReportedPos = encoderPos;
if (digitalRead(clearButton) == HIGH )
delay(20);
UIstate = 1;
encoderPos = 0; //When button is pressed reset counter to 0
void doEncoderA()
if ( rotating ) delay (1); //Wait a little until the bouncing is done
if ( digitalRead(encoderPinA) != A_set )
A_set = !A_set;
if (A_set && !B_set && encoderPos != 10)
encoderPos += 1;
UIstate = 2; //Increment by 1 clockwise
if ( A_set && !B_set && encoderPos == 10)
encoderPos = 10;
rotating = false; //No more debouncing until loop() hits again
void doEncoderB()
if ( digitalRead(encoderPinB) != B_set )
B_set = !B_set;
if ( !A_set && B_set && encoderPos != 0)
encoderPos -= 1;
UIstate = 3;
if (!A_set && B_set && encoderPos == 0)
encoderPos = 0;
rotating = false;
