Rotary encoders not recognised in button box project
Hi there, TLDR: I’m very new to Arduino and have nearly finished a button box project but have run into a problem with the rotary encoders which I can’t solve and am hoping for help.
I’m building a button box based on a modified version of this sketch
Description:
Arduino Leonardo wired to 2 potentiometers, 6 momentary buttons and 5 rotary encoders with push buttons. I’m using the joystick and keypad libraries.
The momentary buttons and rotary encoder buttons wired in a 4x3 matrix. My columns are wired to pins 0 - 3, rows to A3 - 5, potentiometers to A0 and A1.
The encoders are set up with the left and right terminals wired in pairs to pins 4 - 13 (so encoder A is connected to pins 4 and 5, encoder B is connected to 6 and 7, etc). The center pins are all wired to ground.
Problem:
I’ve got everything working aside from the five rotary encoders which aren’t being picked up when I turn them left or right. To rule out a problem with the joystick library or a driver problem, I added some code to print the output to the serial monitor and that is not registering anything from the encoders either.
I’m fairly certain I’ve coded this correctly and as far as I can tell, all the wires are connected properly as well. I was hoping someone could take a look at my code to make sure I haven’t screwed something up… Otherwise my next step is going to be to tear my box apart and redo all my soldering.
Here is my code:
#include <Keypad.h>
#include <Joystick.h>
// ButtonBox
#define ENABLE_PULLUPS
#define NUMROTARIES 5
#define NUMBUTTONS 11
#define NUMROWS 3
#define NUMCOLS 4
byte buttons[NUMROWS][NUMCOLS] = {
  {0,1,2,3},
  {4,5,6,7},
  {8,9,10,11},
struct rotariesdef {
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  volatile unsigned char state;
rotariesdef rotaries[NUMROTARIES] {
  {4,5,12,13,0},
  {6,7,14,15,0},
  {8,9,16,17,0},
  {10,11,18,19,0},
  {12,13,20,21,0},
#define DIR_CCW 0x10
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
#define R_CCW_BEGIN 0x1
#define R_CW_BEGIN 0x2
#define R_START_M 0x3
#define R_CW_BEGIN_M 0x4
#define R_CCW_BEGIN_M 0x5
const unsigned char ttable[6][4] = {
  // R_START (00)
  {R_START_M,            R_CW_BEGIN,     R_CCW_BEGIN,  R_START},
  // R_CCW_BEGIN
  {R_START_M | DIR_CCW, R_START,        R_CCW_BEGIN,  R_START},
  // R_CW_BEGIN
  {R_START_M | DIR_CW,  R_CW_BEGIN,     R_START,      R_START},
  // R_START_M (11)
  {R_START_M,            R_CCW_BEGIN_M,  R_CW_BEGIN_M, R_START},
  // R_CW_BEGIN_M
  {R_START_M,            R_START_M,      R_CW_BEGIN_M, R_START | DIR_CW},
  // R_CCW_BEGIN_M
  {R_START_M,            R_CCW_BEGIN_M,  R_START_M,    R_START | DIR_CCW},
#else
#define R_CW_FINAL 0x1
#define R_CW_NEXT 0x3
#define R_CCW_BEGIN 0x4
#define R_CCW_FINAL 0x5
#define R_CCW_NEXT 0x6
const unsigned char ttable[7][4] = {
  // R_START
  {R_START,    R_CW_BEGIN,  R_CCW_BEGIN, R_START},
  // R_CW_FINAL
  {R_CW_NEXT,  R_START,     R_CW_FINAL,  R_START | DIR_CW},
  // R_CW_BEGIN
  {R_CW_NEXT,  R_CW_BEGIN,  R_START,     R_START},
  // R_CW_NEXT
  {R_CW_NEXT,  R_CW_BEGIN,  R_CW_FINAL,  R_START},
  // R_CCW_BEGIN
  {R_CCW_NEXT, R_START,     R_CCW_BEGIN, R_START},
  // R_CCW_FINAL
  {R_CCW_NEXT, R_CCW_FINAL, R_START,     R_START | DIR_CCW},
  // R_CCW_NEXT
  {R_CCW_NEXT, R_CCW_FINAL, R_CCW_BEGIN, R_START},
#endif
byte rowPins[NUMROWS] = {A4,A5,A3}; //pins connected to rows in button matrix
byte colPins[NUMCOLS] = {0,1,2,3}; //pins connected to columns in button matrix
Keypad buttbx = Keypad( makeKeymap(buttons), rowPins, colPins, NUMROWS, NUMCOLS);
Joystick_ Joystick(JOYSTICK_DEFAULT_REPORT_ID,
  JOYSTICK_TYPE_JOYSTICK,
  22, //number of buttons
  0, //number of hat switches
  false, // y axis
  false, // x axis
  true, // z axis
  true, // rx axis
  false, // ry axix
  false, // rz axis
  false, // rudder
  false, // throttle
  false, // accelerator
  false, // brake
  false); // steering wheel
// potentiometer setup
const int numReadings = 20;
int readings[numReadings];      // the readings from the analog input
int index = 0;              // the index of the current reading
int total = 0;                  // the running total
int currentOutputLevel = 0;
int zAxis_ = 0;
int RxAxis_ = 0;
int RyAxis_ = 0;
int potentiometerPin1 = A0;
int potentiometerPin2 = A1;
const bool initAutoSendState = true;
  Joystick.begin();
  rotary_init();
  // initialize all potentiometer readings to 0:
  for (int thisReading = 0; thisReading < numReadings; thisReading++) {
    readings[thisReading] = 0;
  CheckAllEncoders();
  CheckAllButtons();
  CheckAllPotentiometers();
void CheckAllPotentiometers(){
  // calculate the average:
  currentOutputLevel = getAverageOutput(potentiometerPin1);
  zAxis_ = map(currentOutputLevel,0,1023,0,255);
  Joystick.setZAxis(zAxis_);
  currentOutputLevel = getAverageOutput(potentiometerPin2);
  RxAxis_ = map(currentOutputLevel,0,1023,0,255);
  Joystick.setRxAxis(RxAxis_);
int getAverageOutput(int pinToRead){
  index = 0;
  total = 0;
  while (index < numReadings){
    // get sample
    // read from the sensor:
    readings[index] = analogRead(pinToRead);
    // add the reading to the total:
    total = total + readings[index];
    // advance to the next position in the array:
    index = index + 1;
    delay (1);
  return total / numReadings;
void CheckAllButtons(void) {
      if (buttbx.getKeys())
       for (int i=0; i<LIST_MAX; i++)
           if ( buttbx.key[i].stateChanged )
            switch (buttbx.key[i].kstate) {
                    case PRESSED:
                    case HOLD:
                              Joystick.setButton(buttbx.key[i].kchar, 1);
                    case RELEASED:
                    case IDLE:
                              Joystick.setButton(buttbx.key[i].kchar, 0);
void rotary_init() {
  for (int i=0;i<NUMROTARIES;i++) {
    pinMode(rotaries[i].pin1, INPUT);
    pinMode(rotaries[i].pin2, INPUT);
    #ifdef ENABLE_PULLUPS
      digitalWrite(rotaries[i].pin1, HIGH);
      digitalWrite(rotaries[i].pin2, HIGH);
    #endif
unsigned char rotary_process(int _i) {
  //Serial.print("Processing rotary: ");
  //Serial.println(_i);
  unsigned char pinstate = (digitalRead(rotaries[_i].pin2) << 1) | digitalRead(rotaries[_i].pin1);
  rotaries[_i].state = ttable[rotaries[_i].state & 0xf][pinstate];
  return (rotaries[_i].state & 0x30);
void CheckAllEncoders(void) {
  Serial.println("Checking rotaries");
    unsigned char result = rotary_process(i);
    //Serial.print("Result: ");
    //Serial.println(result);
    if (result == DIR_CCW) {
      Serial.print("Rotary ");
      Serial.print(i);
      Serial.println(" <<< Going CCW");
      Joystick.setButton(rotaries[i].ccwchar, 1); delay(50); Joystick.setButton(rotaries[i].ccwchar, 0);
    if (result == DIR_CW) {
      Serial.print(i);
      Serial.println(" >>> Going CW");
      Joystick.setButton(rotaries[i].cwchar, 1); delay(50); Joystick.setButton(rotaries[i].cwchar, 0);
  Serial.println("Done checking");
I’ve done some more tests and narrowed down my problem. It’s definitely not a wiring problem. The rotaries connected to pins 4,5 and 6,7 work fine using the original code I based my version on:
//BUTTON BOX
//USE w ProMicro
//Tested in WIN10 + Assetto Corsa
//AMSTUDIO
//20.8.17
#include <Keypad.h>
#define NUMROTARIES 4
#define NUMBUTTONS 24
#define NUMROWS 5
#define NUMCOLS 5
  {0,1,2,3,4},
  {5,6,7,8,9},
  {10,11,12,13,14},
  {15,16,17,18,19},
  {20,21,22,23},
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  {0,1,24,25,0},
  {2,3,26,27,0},
  {4,5,28,29,0},
  {6,7,30,31,0},
#define DIR_CW 0x20
#define R_START 0x0
#ifdef HALF_STEP
  // R_START (00)
  // R_CCW_BEGIN
  // R_CW_BEGIN
  // R_START_M (11)
  // R_CW_BEGIN_M
  // R_CCW_BEGIN_M
#else
  // R_START
  // R_CW_FINAL
  // R_CW_BEGIN
  // R_CW_NEXT
  // R_CCW_BEGIN
  // R_CCW_FINAL
  // R_CCW_NEXT
#endif
byte rowPins[NUMROWS] = {21,20,19,18,15};
byte colPins[NUMCOLS] = {14,16,10,9,8};
  JOYSTICK_TYPE_JOYSTICK, 32, 0,
  false, false, false, false, false, false,
  false, false, false, false, false);
  Joystick.begin();
  rotary_init();}
  CheckAllEncoders();
  CheckAllButtons();
                    case PRESSED:
                    case HOLD:
                    case RELEASED:
                    case IDLE:
    #endif
The problem seems to be something to do with “struct rotariesdef”, I’ve discovered that if I change any fields in that segment, the rotaries stop working.
E.G. if I leave it like this the encoders work it works fine:
  byte pin1;
  byte pin2;
  int ccwchar;
  int cwchar;
  {0,1,24,25,0},
  {2,3,26,27,0},
  {4,5,28,29,0},
  {6,7,30,31,0},
But if I swap around the pin inputs for the final two lines like this, it stops working:
  {0,1,24,25,0},
  {2,3,26,27,0},
  {6,7,28,29,0},
  {4,5,30,31,0},
Does anyone know why changing the inputs around like this would cause me a problem?
