again, i got it all working, i am just not sure this is the way to do it, as in the code bellow.
#include <EEPROM.h>
#include <LedControl.h>
#include <ezButton.h>
#include <TimeLib.h>
#include <RTClib.h>
#include <OneWire.h>
#include <DS1307RTC.h>
#define MAXIMCCLD 12 // output - CS/LOAD
#define MAXIMCCCLK 11 // output - CLOCK
#define MAXIMCCDATA 10 // output - DATA
#define DS1307_I2C_ADDRESS 0x68 // define the RTC I2C address
ezButton button(7); // create ezButton object that attach to pin 7;
LedControl MaximCC=LedControl(MAXIMCCDATA, MAXIMCCCLK, MAXIMCCLD, 1); // Define pins for Maxim 72xx and how many 72xx we use
int LED = 5;
int LED2 = 9;
volatile signed int counter_hour_start = EEPROM.read(2);
volatile signed int counter_minute_start = EEPROM.read(3);
volatile signed int counter_hour_end = EEPROM.read(4);
volatile signed int counter_minute_end = EEPROM.read(5);
// usually the rotary encoders three pins have the ground pin in the middle
enum PinAssignments {
encoderPinA = 2, // right
encoderPinB = 3, // left
// a counter for the dial
signed int lastReportedPos_hour_start = 1; // change management
signed int lastReportedPos_minute_start = 1; // change management
signed int lastReportedPos_hour_end = 1; // change management
signed int lastReportedPos_minute_end = 1; // change management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
int previousSecond = 0;
int tensofhours, singlehours, tensofminutes, singleminutes,tensofhours1, singlehours1, tensofminutes1, singleminutes1;
// SETUP
pinMode(LED, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, doEncoderB, CHANGE);
MaximCC.shutdown(0,false);
MaximCC.setIntensity(0,15);
MaximCC.clearDisplay(0);
button.setDebounceTime(50); // set debounce time to 50 milliseconds
button.setCountMode(COUNT_FALLING);
setSyncProvider(RTC.get); // the function to get the time from the RTC
tensofhours = counter_hour_start / 10;
singlehours = counter_hour_start % 10;
tensofminutes = counter_minute_start / 10;
singleminutes = counter_minute_start % 10;
tensofhours1 = counter_hour_end / 10;
singlehours1 = counter_hour_end % 10;
tensofminutes1 = counter_minute_end / 10;
singleminutes1 = counter_minute_end % 10;
// LOOP
tasksEverySecond();
button.loop(); // MUST call the loop() function first
unsigned long count = button.getCount();
if (count>0) {
encoder_alarm();
// tasksEverySecond
void tasksEverySecond()
if (second() != previousSecond)
previousSecond = second();
displayRtcTime();
ledTest();
// ENCODER ALARM
void encoder_alarm(){
// reset button count when we cycle through all digit groups and set an alarm
if (count > 6) {
button.resetCount();
digitalWrite(LED, LOW);
//--------------------- HOURS alarm STARTS at ------------------------//
if (lastReportedPos_hour_start != counter_hour_start) {
if (counter_hour_start>23) {(counter_hour_start = 0);}
if (counter_hour_start<0) {(counter_hour_start = 23);}
lastReportedPos_hour_start = counter_hour_start;
EEPROM.update(2,counter_hour_start);
//--------------------- MINUTES alarm STARTS at ------------------------//
if (lastReportedPos_minute_start != counter_minute_start) {
if (counter_minute_start>59) {(counter_minute_start = 0);}
if (counter_minute_start<0) {(counter_minute_start = 59);}
lastReportedPos_minute_start = counter_minute_start;
EEPROM.update(3,counter_minute_start);
//--------------------- 7 Segment display ------------------------//
if (count == 1 || count == 6) {
MaximCC.setChar(0,7,tensofhours,false);
MaximCC.setChar(0,6,singlehours,true);
MaximCC.setChar(0,5,tensofminutes,false);
MaximCC.setChar(0,4,singleminutes,true);
MaximCC.setChar(0,3,tensofhours1,false);
MaximCC.setChar(0,2,singlehours1,true);
MaximCC.setChar(0,1,tensofminutes1,false);
MaximCC.setChar(0,0,singleminutes1,true);
digitalWrite(LED, HIGH);
if (count == 2) {
} else if (count != 1 && count != 6){
MaximCC.setChar(0,6,singlehours,false);
if (count == 3) {
} else if (count != 1 && count != 6) {
MaximCC.setChar(0,4,singleminutes,false);
if (count == 4) {
MaximCC.setChar(0,2,singlehours1,false);
if (count == 5) {
MaximCC.setChar(0,0,singleminutes1,false);
// displayRtcTime
void displayRtcTime()
if (count == 0){
MaximCC.setChar(0, 7, (hour() / 10), false);
MaximCC.setChar(0, 6, (hour() % 10), false);
MaximCC.setChar(0, 5, '-', false);
MaximCC.setChar(0, 4, (minute() / 10), false);
MaximCC.setChar(0, 3, (minute() % 10), false);
MaximCC.setChar(0, 2, '-', false);
MaximCC.setChar(0, 1, (second() / 10), false);
MaximCC.setChar(0, 0, (second() % 10), false);
// ledTest
void ledTest(){
int midnight;
int powersaving;
int startTime = counter_hour_start * 100 + counter_minute_start;
int endTime = counter_hour_end * 100 + counter_minute_end;
int timeNow = hour() * 100 + minute();
if (endTime == 0000 && startTime != 0000){
endTime = 2359;
if (timeNow >= startTime && timeNow < endTime) {
powersaving = true;
powersaving = false;
if (powersaving == true){
digitalWrite(LED2, HIGH);
digitalWrite(LED2, LOW);
// Interrupt on A changing state
void doEncoderA() {
// Test transition, did things really change?
if ( digitalRead(encoderPinA) != A_set ) { // debounce once more
A_set = !A_set;
// adjust counter + if A leads B
if (( A_set && !B_set ) && (count == 2))
counter_hour_start += 1;
if (( A_set && !B_set ) && (count == 3))
counter_minute_start += 1;
if (( A_set && !B_set ) && (count == 4))
counter_hour_end += 1;
if (( A_set && !B_set ) && (count == 5))
counter_minute_end += 1;
// Interrupt on B changing state, same as A above
void doEncoderB() {
if ( digitalRead(encoderPinB) != B_set ) {
B_set = !B_set;
// adjust counter - 1 if B leads A
if (( B_set && !A_set ) && (count == 2))
counter_hour_start -= 1;
if (( B_set && !A_set ) && (count == 3))
counter_minute_start -= 1;
if (( B_set && !A_set ) && (count == 4))
counter_hour_end -= 1;
if (( B_set && !A_set ) && (count == 5))
counter_minute_end -= 1;
I am not sure if leaving too many if statements in the interrupt routine is OK? As i need different reading depending on the button count. the code looks dirty to me, i am sure there is a cleaner/better/proper solution, its just i can not figure it out.
Thanks,
Alek
