Rotary Enoder and position
Hi everyone. I have a project where I want to know the position of a pole over 360 degree. I only do one turn from 0 to 360 degree.
I found that best solution is rotary Encoder. I do understand the principle, but can't find one encoder to buy (too many model).
The pole is 50 feet away from the Arduino board and outside with temperature range from -30 to 30 degree Celsius.
I think I need an absolute encoder as I want the current direction of the pole when I need it. (or maybe I could use an incremental encoder and track it with the Arduino board).
Anyway, if someone can help understand what I need it would be greatly appreciated. :slight_smile:
An absolute encoder would work but they tend to use a lot more pins or utilize a serial data format. What you might research is a quadrature encoder with an index output. This supplies an additional output signal that is active at one specific position per revolution. This can be used as a home position indicator.
Lefty
Sounds like you want a potentiometer with a local amplifier. Digikey, among others, sells pots optimized for use as absolute rotary position sensors. Driving the signal over a 50 ft line is a bit tricky -- I think you probably want a voltage to current converter on the transmitter side combined with a simple resistor to turn the current back in to a voltage at the Arduino end.
Thanks for your reply. I actually use a potentiometer to "act like" a rotary encoder in other project, but potentiometer are not 360 degree rotable. and the precision obtained at extremity is not really great (even if I use linear pots).
What is the output of an quadrature encoder? what kind of resolution could I expect?
I think these potentiometers are used in Weather Station Wind Vane sensors. http://www.robotronics.com/products-topmenu-26.html?page=shop.product_details&flypage=flypage-ask.tpl&product_id=1400&category_id=24
Perhaps a standard pot with a 1-to-2 gearing so you would only use 180 degrees of its travel?
Ran
Vitesse: get a potentiometer that is sold as a rotary position sensor. They are going to be more expensive, but they will rotate 360 degrees and give you what you need.
Check out Series HRS100 Hall Effect Rotary Position Sensor (Discontinued Product). It's a hall-effect rotary position sensor for about $30. It outputs an analog voltage proportional to shaft angle. I haven't used that one, but I've used similar and they are quite nifty.
