Hi.
In order to make simple animations with my graphic LCD (128x64), I wrote a function that rotates bitmap images by an arbitary angle and then draws it using an altered DrawBitmap-function Arduino Playground - GLCDks0108 which is part of the ks0108 library by mem.
I'm very new to C and libraries, so it is very likely that I did everything the way I shouldn't have - I'm happy if you correct my code - but it's definitely working.
See what the turning dolphin looks like:
http://www.wunderwald.ch/pics/delfin_am_eintauchen.avi
That is the Sketch:
#include <ks0108.h>
#include <ks0108_Panel.h>
#include <SystemFont5x7.h> // system font
#include <delfin_am_eintauchen_56x56.h> // Bitmap
* Bitmap Rotation
* Programm rotates a bitmap from PROGMEM, stores the rotated image in an array in RAM
* and displays the rotated image. Non-square images might get cropped.
unsigned long startMillis;
unsigned int iter = 0; // used to calculate the frames per second (FPS)
float winkel = 0; // angle the bitmap is to be rotated by
void setup(){
Serial.begin(57600);
GLCD.Init(NON_INVERTED); // initialise the library, non inverted writes pixels onto a clear screen
GLCD.ClearScreen();
GLCD.SelectFont(System5x7); // switch to fixed width system font
void Rotate_and_Draw_Bitmap(const uint8_t * bitmap, float winkel, uint8_t x, uint8_t y, uint8_t color){
uint8_t width, height;
width = ReadPgmData(bitmap++); // Read the image width from the array in PROGMEM
height = ReadPgmData(bitmap++); // Read the height width from the array in PROGMEM
float altes_x, altes_y, neues_x, neues_y; // old and new (rotated) Pixel-Coordinates
float drehpunkt_x = width / 2 + 0.5; // Calculate the (rotation) center of the image (x fraction)
float drehpunkt_y = height / 2 + 0.5; // Calculate the (rotation) center of the image (y fraction)
float sin_winkel = sin (winkel); // Pre-calculate the time consuming sinus
float cos_winkel = cos (winkel); // Pre-calculate the time consuming cosinus
uint8_t gedrehtes_bild[height/8*width+2]; // Image array in RAM (will contain the rotated image)
for (int i = 0; i < height/8*width+2; i++){gedrehtes_bild[i] = 0;} // Clear the array
int i, j, counter = 0;
gedrehtes_bild[0] = width; // First byte of the rotated image contains (as the original) the width
gedrehtes_bild[1] = height; // Second byte of the rotated image contains (as the original) the height
for(i = 0; i < height * width / 8; i++) { // i goes through all the Bytes of the image
uint8_t displayData = ReadPgmData(bitmap++); // Read the image data from PROGMEM
for(j = 0; j < 8; j++) { // j goes through all the Bits of a Byte
if(displayData & (1 << j)){ // if a Bit is set, rotate it
altes_x = ((i % width) + 1) - drehpunkt_x; // Calculate the x-position of the Pixel to be rotated
altes_y = drehpunkt_y - (((int)(i/width))*8+j+1); // Calculate the y-position of the Pixel to be rotated
neues_x = (int) (altes_x * cos_winkel - altes_y * sin_winkel); // Calculate the x-position of the rotated Pixel
neues_y = (int) (altes_y * cos_winkel + altes_x * sin_winkel); // Calculate the y-position of the rotated Pixel
// Check if the rotated pixel is withing the image (important if non-square images are used). If not, continue with the next pixel.
if (height == width || (neues_x <= (drehpunkt_x - 1) && neues_x >= (1 - drehpunkt_x) && neues_y <= (drehpunkt_y - 1) && neues_y >= (1 - drehpunkt_y))){
// Write the rotated bit to the array (gedrehtes_bild[]) in RAM
gedrehtes_bild[(int)(neues_x + drehpunkt_x)%width + ((int)((drehpunkt_y - neues_y - 1) / 8)*width) +2] |= (1 << (int)(drehpunkt_y - neues_y - 1)%8);
GLCD.DrawRamBitmap(gedrehtes_bild,x,y,color); // Draw the rotated image
void loop(){ // run over and over again
iter = 0;
startMillis = millis();
while( millis() - startMillis < 1000){ // loop for one second
winkel += 5; // increase angle by 5 degrees
Rotate_and_Draw_Bitmap(delfin_am_eintauchen_56x56, winkel/57, 50,8, BLACK); // Division by 57, because the function expects an angle in radians, not degrees.
iter++;
//display number of iterations in one second
GLCD.CursorTo(0,0); // positon cursor
GLCD.Puts("FPS="); // print a text string
GLCD.PrintNumber(iter); // print the number of iterations per second
That is the extension you have to add to ks0108.cpp (Section «public»):
void DrawRamBitmap(const uint8_t * bitmap, uint8_t x, uint8_t y, uint8_t color);
That is the extension you have to add to ks0108.h:
void ks0108::DrawRamBitmap(const uint8_t * bitmap, uint8_t x, uint8_t y, uint8_t color){
uint8_t i, j;
int z = 0;
width = bitmap[z++];
height = bitmap[z++];
for(j = 0; j < height / 8; j++) {
this->GotoXY(x, y + (j*8) );
for(i = 0; i < width; i++) {
uint8_t displayData = bitmap[z++];
if(color == BLACK)
this->WriteData(displayData);
this->WriteData(~displayData);
That is the image that I used in the example:
And here comes the headerfile the image was converted to using glcd2bitmap:
/* delfin_am_eintauchen_56x56.h bitmap file for GLCD library */
/* Bitmap created from delfin_am_eintauchen_56x56.bmp */
/* Date: 17 Feb 2010 */
#include <inttypes.h>
#include <avr/pgmspace.h>
#ifndef delfin_am_eintauchen_56x56_H
#define delfin_am_eintauchen_56x56_H
static uint8_t delfin_am_eintauchen_56x56[] PROGMEM = {
56, // width
56, // height
/* page 0 (lines 0-7) */
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
/* page 1 (lines 8-15) */
0x0,0xc0,0xc0,0x80,0x0,0x0,0x0,0x0,0x0,0x80,0x80,0x80,0x80,0x80,0xc0,0xc0,
0xc0,0xc0,0xc0,0xe0,0xc0,0xe0,0xe0,0xc0,0xe0,0x60,0x40,0xf0,0xb0,0xc0,0x80,0x0,
/* page 2 (lines 16-23) */
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80,0x80,0xe0,
0x7e,0x3f,0x1,0x3,0x3,0x2,0x3,0x3,0x3,0xc3,0x60,0xd1,0x29,0x14,0x1c,0xe,
0x6,0x7,0x1,0x3,0x1,0x0,0x1,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
/* page 3 (lines 24-31) */
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x80,0xf0,0x7c,0x14,0x7,0x3,0x0,
0x0,0x0,0x80,0xc0,0xe0,0x38,0x38,0xe,0x3,0x3,0x0,0x0,0x0,0x0,0x0,0x0,
/* page 4 (lines 32-39) */
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x78,0xff,0xc1,0x0,0x88,0xe0,0xf0,0x3c,
0xc,0xc,0xf,0xe,0x6,0x2,0x2,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,
/* page 5 (lines 40-47) */
0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0x1,0xf,0xf,0x7,0x1,0x0,0x0,
/* page 6 (lines 48-55) */
#endif
Hope, you can use it!
Thanks for your input,
Dani
