Hi, I'd like to assemble a standalone rotor for an action cam like a GoPro. Basically i need a rotating base where to put the cam.
Rotation speed should be very slow like 60sec for 360°.
I was looking for this servo motor
My Italian is almost non-existent and I cannot tell whether that servo just moves through 180 degrees or whether it is a continuous rotation servo.
You cannot control the position of a continuous rotation servo - only speed and direction. They can move slowly but you would need to experiment to determine the slowest speed. If it is too fast perhaps you could use gearing or a belt-drive to get a slower speed.
Servos which are NOT continuous-rotation move quickly but you can slow them down by instructing them to move in small steps as in the servo sweep example that comes with the Arduino IDE. But the movement might be too jerky for what you want.
