Rotation counter and motor shut off for yarn skein winder
Hello everyone,
Advance thanks for any help I can get here! I'm very new to Arduino but have been reading for years about all the amazing things they can do.
I'd like to build my wife a skein winder. What's that you ask? A skein winder spins to take up yarn off a spindle to create something called a skein (which is just a specific length of yarn).
The skein winder I plan on building will look something like this:
http://www.fricke-fiber-tools.com/electricwinders.html
Now for MY QUESTION: Can I use Arduino to count rotations of the winder and then stop the motor? This function would allow us to repeatedly make skeins of a consistent length.
I feel deep in my gut that someone out there has an answer or at least a direction to look. Any help would be greatly appreciated!
Hello,
short question "can it be done"? Short answer "Yes".
Longer answer, one usually puts a magnet on the part that is turning (in your case, the wheel where the skein is being built onto). Then, you put a magnet sensor. This can be something called a Hall Effect or something like a magnetic reed Switch. Every time that magnet passes the sensor/Switch, it generates an Input to a digital Input pin on the Arduino.
Another Technology is to not use a "simple" DC Motor but something called a stepper Motor. They are more expensive but the Arduino can tell them to take a step. Often it takes 200 such steps to equal one Rotation so the Arduino is in very fine control of how fast/often the device spins.
Whether you use a simple DC Motor or a stepper Motor, you can't power it directly from the Arduino. The Arduino Pins can only supply 20 mA of power. You will Need a Transistor or MOSFET or (for a stepper) a Controller to do that.
Using the key words from my answer, you will find thousands of suggestions on the Forum on how to proceed.
Thank you so much for walking me through that! Your help really means a lot to this newbie.
Alternatives to a magnet and a hall-effect sensor are ...
a slotted optical switch in which a tag on the shaft breaks the beam within the switch
or
a reflective optical switch which just needs a blob of white paint on the shaft. If you need to count half revolutions you could use 2 blobs of white paint.
A more sophisticated solution would be a rotary encoder but they are more difficult to program for and would really only make sense if you need control over fractional revolutions.
I also suspect a stepper motor would be overkill for this application and a simple geared DC motor would be sufficient. I presume the skein will not be rotating fast.
...R
OPs picture.
Tom... :slight_smile:
A reflective optical detector on the upright could detect each arm as it passed.
...R
