so how do you know how many digits you need to print? where was that in your code?
in the code @jfjlaros offered, m is your cue
float myNum[] =
11.871, 11.177, 37.233, 37.779, 0.578, 0.544,
0.0257, 0.0223,0.000345
for (int i = 0; i < 4; i++)
Serial.println(myNum[i], 0);
for (int i = 4; i < 6; i++)
Serial.println(myNum[i], 1);
for (int i = 6; i < 8; i++)
Serial.println(myNum[i], 2);
for (int i = 8; i < 9; i++)
Serial.println(myNum[i], 4);
void loop(){}
Output:
12
11
37
38
0.6
0.5
0.03
0.02
0.0003
I like your sense of humour
That's why I did not post my codes at the very first post. I thought that OP will ask me for the codes and the way of saving the results in variables; as a result, I will have some hard tasks to do.
waste of bandwidth and storage
fabs()
abs() and fabs () functions, both are used to retrieve or calculate the absolute value. The only difference between both of them is, abs() is used to calculate the absolute value for integer type numbers whereas fabs() are used for floating type numbers.
Try this, it just uses the round(number) function:
#include <Arduino.h>
#include <Wire.h>
#include <SoftwareSerial.h>
float rounded_number = 0;
float number = 0;
void _delay(float seconds) {
long endTime = millis() + seconds * 1000;
while(millis() < endTime) _loop();
number = "<Your Number>";
rounded_number = round(number);
void _loop() {
_loop();
really ???
This is apparently how it is implemented.
#define abs(x) ((x)>0?(x):-(x))
post # number, please!
post #5 #8 or #10
float myRound(float f) {
if (f == 0) return 0;
float m = 1;
while (abs(f * m) < 1) m *= 10;
return round(f * m) / m;
I have uploaded that sketch @jfjlaros ; but, the outcome does not match with what OP wants.
float myNum[] =
0.0257, 0.0223, 0.000345
for (int i = 0; i < 9; i++)
float x = myRound(myNum[i]);
Serial.println(x, 4);
if (f == 0)
return 0;
float m = 1;
m *= 10;
Output:
12.0000
11.0000
37.0000
38.0000
0.6000
0.5000
0.0300
0.0200
0.0003
OP wants:
12
11
37
38
0.60
0.50
0.03
0.02
0.0003
as you said, OP did not say if he wants a variable or a print out
with float anyway some numbers are not representable and so any math you do with them leads to approximation
Indeed, plus I would argue that formatting the result should be done in a different function anyway.
to be completely honest, m in this code is not what mathematically we would expect it to be
float m = 1;
as the float representation of f might not match the true value that was originally provided. So you are already on moving sand from the start
