// FILE: roundUp.ino
// AUTHOR: Rob Tillaart
// VERSION: 0.1.00
// PURPOSE: demo
// DATE: 2015-12-05
// URL: http://forum.arduino.cc/index.php?topic=363883.0
// Released to the public domain
Serial.print("Start ");
Serial.println(__FILE__);
for (int x = 1; x <= 1000; x++)
for (int y = 1; y <= 25; y++)
Serial.print("\t");
Serial.print(roundUp(x, y));
for (int x = -50; x <= 50; x++)
Serial.print("\t");
Serial.println("done");
long roundUp(long val, long factor)
long rem = val % factor;
val -= rem;
if (rem > 0) val += factor;
return val;
@Jos, works perfectly in positive domain, in the negative domain it fails.
int n = -11000;
int up= ((n+999)/1000)*1000;
up ==> n+999 => -10001 / 1000 => -10 * 1000 = -10000
QED
Furthermore the function (inlined) is ~10% faster on AVR as it uses only one DIV/MUL operator while formula uses two. (that are the expensive ones, esp DIV) But yes that will only matter when performance is an issue.
Let me go into a little more specific explanation. I have a control panel that shows altitude in increments of a 1000ft adjusted by turning a knob which is hooked to a position sensor. The sensor outputs an angle which I want to convert to the altitude shown on the front of the panel. It reads from 1000 to 37000 ft Here is the map function part of my code.
737nut:
Rob
Sorry, but actually, that's not very specific. What do the digits look like? Does it actually display only 1-37 and the "000" is a hard printed mask, or what? Is it an analogue or digital display? Also, why are the answers that were given to your question not applicable?
(I can now see why negative values are not relevant...)
737nut:
Alt = map(deg, 92, 187, 1000, 37000);
I guess another option might be an Array?
Thanks for any ideas,
Rob
How accurate is that angle?
Is it correct to map it in a linear way? gonio math is seldom linear...
As you have only 95 angles a lookup table might just work.
byte lut[95] = { 1,1,2,2, ...37 }; // could be in PROGMEM
lcd.print(lut[deg-92]*1000);
