Rounding to 1 decimal place, and LCD problem
i am relatively new to arduino and I have been putting together a i2c lcd "thermostat" as a start to a bigger project i have in mind.
I have recently add smoothing to the TMP36 part of the code but for some reason the first 5 or what ever you put as the numReadings are incorrect data starting off as minus and then slowly working they way up to the correct figure which messes up how it is displayed on the lcd.
I am also looking to round the tmp36 data to 1 decimal place i have tried
"tempC = round(tempC*10)/10;
but just results in rounding to e.g 22.00 for 21.87 . I was wondering whether anyone could point me in the right direction to solving these problems, also if anyone could point out how my code could be tidy up/made better that would be much appreciated.
thanks
#include <Wire.h>
LiquidCrystal_I2C lcd(0x3f,20,4);  // set the LCD address
#define aref_voltage 3.3           // 3.3v analog reference
//TMP36 Pin Variables
int tempPin = 1;                   //Tmp 36 data pin
                                   //the resolution is 10 mV / degree centigrade with a
                                   //500 mV offset to allow for negative temperatures
const int numReadings = 5;
int readings[numReadings];         // the readings from the analog input
int readIndex = 0;                 // the index of the current reading
int total = 0;                     // the running total
int average = 0;                   // the average
  Serial.begin(9600); // serial setup
  lcd.init();                        // initialize the lcd
  lcd.backlight();                   // Backlight on
  lcd.setCursor(0,0);                // set Cursor to the Top left
  lcd.print("Temperature:       C"); // print temperature with space for data
  lcd.setCursor(18,0);
  lcd.print((char)223);              // print degree symbol
  lcd.setCursor(3,1);
  lcd.print("Set Temp:       C");    // print Set temp: with space for data
  lcd.setCursor(18,1);
  analogReference(EXTERNAL);         // If you want to set the aref to something other than 5v
  for (int thisReading = 0; thisReading < numReadings; thisReading++)
    readings[thisReading] = 0;
  total = total - readings[readIndex];           // subtract last reading
  readings[readIndex] = analogRead(tempPin);     //read the tmp36 data pin
  total = total + readings[readIndex];           // add reading to the total
  readIndex = readIndex + 1;                     // advance to the next postion in the array
  if (readIndex >= numReadings)                  // if we are at the end of the array
    readIndex = 0 ;                              // go back to the beginning
  average = total / numReadings;
  float voltage = average * aref_voltage;        // convert the reading in to mV
  voltage /= 1024.0;
  float TempC = (voltage - 0.5) * 100;           // convert from 10mV per c with 500mV offset
 if (TempC < 10)
  lcd.setCursor(13,0);
  lcd.print(" ");
  lcd.print(TempC);
  lcd.print(TempC);
 Serial.println(TempC);
Prevent the compiler defaulting to integer calculations
  tempC = round(tempC * 100.0) / 100.0;
//lcd.print(TempC);
lcd.print(TempC,1);
Changing that line will round and print the float value to one decimal place.
You have a running average which starts with all values at 0 so the value will work its way up through the 5 readings.
You can take one analogRead() of the sensor in setup() and initialize the array with a value other than 0.
