Rounding to one decimal place when using OneWire, Dallastemperature, and LCD
I have some code that does what I want it to do except round to one decimal place when displayed on my LCD screen. Does anyone have any suggestions? The code is listed below. Thanks in advance!
// DS18B20 2 sensors with LCD
// This Arduino sketch reads DS18B20 "1-Wire" digital
// temperature sensors.
// Tutorial:
// Arduino 1-Wire Tutorial
#include <OneWire.h>
#include <DallasTemperature.h>B20
#include <LiquidCrystal.h>
#include <SPI.h>
// Connections:
// rs (LCD pin 4) to Arduino pin 12
// rw (LCD pin 5) to Arduino pin 11
// enable (LCD pin 6) to Arduino pin 10
// LCD pin 15 to Arduino pin 13
// LCD pins d4, d5, d6, d7 to Arduino pins 5, 4, 3, 2
LiquidCrystal lcd(12, 11, 10, 5, 4, 3, 2);
int backLight = 13; // pin 13 will control the backlight
// Data wire is plugged into pin 8 on the Arduino
#define ONE_WIRE_BUS 8
// Setup a oneWire instance to communicate with any OneWire devices
OneWire oneWire(ONE_WIRE_BUS);
// Pass our oneWire reference to Dallas Temperature.
DallasTemperature sensors(&oneWire);
// Assign the addresses of your 1-Wire temp sensors.
// See the tutorial on how to obtain these addresses:
// http://www.hacktronics.com/Tutorials/arduino-1-wire-address-finder.html
DeviceAddress roomTemp = {
0x28, 0x9C, 0x99, 0x26, 0x04, 0x00, 0x00, 0x71 };
DeviceAddress ductTemp = {
0x28, 0xE3, 0xC5, 0xAF, 0x04, 0x00, 0x00, 0x33 };
void setup(void)
// Start up the library
sensors.begin();
// set the resolution to 10 bit (good enough?)
sensors.setResolution(roomTemp, 10);
sensors.setResolution(ductTemp, 10);
pinMode(backLight, OUTPUT);
digitalWrite(backLight, HIGH); // turn backlight on. Replace 'HIGH' with 'LOW' to turn it off.
lcd.begin(16,2); // columns, rows. use 16,2 for a 16x2 LCD, etc.
lcd.clear(); // start with a blank screen
void printTemperature(DeviceAddress deviceAddress)
float tempC = sensors.getTempC(deviceAddress);
if (tempC == -127.00) {
lcd.print("Error");
else {
tempC=tempC*1.8+32;
lcd.print(tempC);
lcd.print("/");
lcd.print(DallasTemperature::toFahrenheit(tempC));
void loop(void)
delay(6000);
sensors.requestTemperatures();
lcd.setCursor(0,0);
lcd.print("Room Temp: ");
printTemperature(roomTemp);
lcd.setCursor(0,1);
lcd.print("Duct Temp: ");
printTemperature(ductTemp);
If you look at the LiquidCrystal library, you'll see that the class derives from Print. So, the lcd.print() method is actually the Print::print() method. It you look at the documentation for the print() method, you'll see that it sometimes takes a second argument. For the method that prints floats, the second argument defines the number of decimal places desired.
I tried it like this and it did not work. I also tried it with putting the ,1 after each tempC still no dice. Any other suggestions?
// Tutorial:
#include <SPI.h>
// Connections:
// Arduino 1-Wire Address Finder
void setup(void)
sensors.begin();
lcd.print("Error");
else {
tempC=tempC*1.8+32;
lcd.print(tempC,1);
lcd.print("/");
void loop(void)
delay(6000);
lcd.setCursor(0,0);
lcd.setCursor(0,1);
Well, that makes it easy to help you. Something happened when you ran that code. You haven't told us what!
   tempC=tempC*1.8+32;
The value, in degrees Celsius, returned by the sensor, when multiplied by 1.8 and incremented by 32 is now a temperature in degrees Fahrenheit. Why are you storing that in tempC?
Why are you then passing the Fahrenheit temperature to a function that converts the temperature from Celsius to Fahrenheit?
Thank you PaulS! You made my day by pointing in the right direction.
It works for Serial.print as well.
I searched a day until I found this post. Just in case someone else lands on this old post:
Serial.print("Error getting temperature");
Serial.print("C: ");
Serial.print(tempC,1); // The 1 behind the tempC (second argument) defines the numbers of digits required
It may just be that it's only been documented in the last eighteen months (I doubt it) but it's documented here.
