Hello,
I'm using a DC motor and I want to know how many rounds it makes. Is there something I can use for that? Mechanical?
Thanks in advance.
PMVisser
Hello,
Thanks in advance.
PMVisser
For high resolution feedback an optical encoder will be used. For lower resolution (and lower price) you could use a magnet attached to the motor shaft and a Hall effect sensor. The magnet solution is nice because it's fairly easy to just glue a magnet on, whereas it could be more difficult to interface an optical encoder with a motor. You can buy DC motors with an integrated encoder.
PMVisser:
Just be sure to use a big enough datatype to hold the number.
An int
will crap out at 32768. An unsigned int
will crap out at 65536.
A long
will get you up to about two billion (to be exact, it craps out at 2147483648).
An unsigned long
will get you up to a little more than four billion (it craps out at 4294967296).
Beyond that, well, there is a trick or two you can use, but better to get what you have up and running first.
