Rover won't drive after turning around
I'm working on this rover for a school project. The idea is that the rover drives along and when it sees the IR data being sent by a sensor, it stops, turns around, and the drives back, stopping when it has driven for the same amount of time it took to get to the data, so ideally, it should be back to where it started The program runs normally up until the rover goes to return home, it turns around... and nothing. The function that is called is the same one called earlier for the main driving function, which works fine, the bluetooth communication also continues to readout as if everything was normal, and the motor on one side appears to twitch occasionally, immediately after when the function gets called. I'm using an SN75441ONE H-bridge.
//version:1.3.3 (Motor Trim)
//Created by Reuben Colin Buckley on the 10th May 2021
//Last updated on the 21st May 2021
//About this program
//Early Versions of this ran off a Device state system, where the rover would "check off" a bunch of 'while' commands
//by changing a variable integer called 'devstate' everytime a certain criteria/goal was met (for example, when the
//vehicle recived an ir input, it would change the devstate and that would allow the next section of code to run) this
//would almost always set devstate to 'devstate'++ and thus the next while statement would read true the next time
//the code looped. This allowed the actual loop to run as many times per second as possible and meant the code had a
//near zero latency. Update 1.3 expanded on this todo list system, by having 90% of the orperations as a callable
//function (I.e, void MyFunction(){}, then called as: My Function();), meaning that now instead of only being able
//to run through once, the code becomes entirly modular and allows for quick expansion as well as allowing functions
//to be called multiple times, allowing more complex tasks to be done while using less device memory.
//#include <SPI.h>
//#include <SD.h>             //warning #include<SD.h> is 609 bytes!
#include <SoftwareSerial.h>
#include <IRremote.h>
int devstate = 0;
int Reset = 8;
String devversion = "1.3.3";
String batlvl = "N/a";
int sensedata = 0;
String devname = "Soil Moisture Puck";
int cmdln;
String command;
SoftwareSerial BT(3, 4);       //RX pin | TX pin
const int turntime = 5;          //trims how long rover takes to turn 1 degree
//Motor A
const int motorPin1  = 9;
const int motorPin2  = 10;
//Motor B
const int motorPin3  = 6;
const int motorPin4  = 5;
int EN1 = 11;
int EN2 = 12;
unsigned long StartTime = 0;        //resets the log clock
unsigned long DriveTime = 0;        //resets the Drive clock
const int RECV_PIN = 7;             //defines IR reciver pin
IRrecv irrecv(RECV_PIN);
decode_results results;
//File datalog;
//File devcache;
//Functions
void Mstp()                         //Stop Motors Function
  digitalWrite(motorPin1, LOW);
  digitalWrite(motorPin2, LOW);
  digitalWrite(motorPin3, LOW);
  digitalWrite(motorPin4, LOW);
  digitalWrite(EN1, LOW);
  digitalWrite(EN2, LOW);
void Mfwd()                         //Drive Forward Function
  digitalWrite(motorPin1, HIGH);
  digitalWrite(motorPin3, HIGH);
  Mtrim();
void Mtrim()                        //Differential Steering Trim, helps the rover drive straight
  int counter = 0;
  int right = 10;
  int left = 20;
    delay(1);
    digitalWrite(EN1, HIGH);
    digitalWrite(EN2, HIGH);
    if(right > left){
      delay(left);
      delay(right - left);
    else if(right == left){
      delay(right);
      delay(left - right);
    else if(right < left){
      delay(right);
void reboot()                       //Restarts the rover so it can get sent out freash. Had issues with this causing a reset when booting as there's no way to stop the arduino setting the pins to high breifly on startup, hence this is disconnected on the rover and only serves to stop the code at the moment.
  Serial.println("Restarting");
  BT.println("Restarting");
  digitalWrite(Reset, HIGH);
void get_name()                     //This function is for the use of advanced data recieving, which requires intergers decoded into strings of data. Possible future updates will make use of this function
void irinput()                      //When the rover recieves an IR signal, it runs this function.
  sensedata = results.value;
  Serial.println(sensedata, HEX);
  BT.println(sensedata, HEX);
  irrecv.resume();
  Serial.print("Device_STATE:");
  Serial.println(devstate);
  //BT.print("Device_STATE:");
  //BT.println(devstate);
  if (sensedata > 0) {
    Serial.read();
    BT.read();
    Serial.println("Data saved");
    BT.println("Data saved");
void get_data()                    //This function recalls the data collected and displays it over the serial monitor and over the bluetooth terminal along with some presets that in future could be determined by the Soil moisture puck (name, battery level, etc)
  Serial.println("");
  Serial.println("Retrieving Latest Data...");
  Serial.println("");
  BT.println("");
  BT.println("Retrieving Latest Data...");
  BT.println("");
  if (sensedata == 0) {
    Serial.println("NO_DATA!");
    BT.println("NO_DATA!");
    get_name();
    Serial.println(results.value, HEX);
    BT.println("");
    BT.println("Data found");
    BT.println("");
    BT.println("-----------------------");
    BT.println("| " + devname + "  |");
    BT.print("| Battery level: ");
    BT.print(batlvl);
    BT.println("% |");
    BT.print("|      Data: ");
    BT.print(sensedata);
    BT.println("     |");
    BT.println(results.value, HEX);
void pingconnected()                //Other than checking to see if the rover is still on talking terms with the bluetooth terminal, it doesn't do anything else
  Serial.println("One day this will actually do something");
  BT.println("");
  BT.println("One day this will actually do something");
  BT.println("");
void search()                       //When this is run, all the rover sees is GO GO GO! But seriously, this function tells the rover to start searching for the soil moisture puck
  devstate = 1;               //sets the device state to search mode
  Serial.println("Searching...");
  BT.println("Searching...");
  DriveTime = millis();        //resets the Drive clock
  BT.println("");
void commandpromt()
  Serial.println("testing");
  if (BT.available())
    Serial.println("tester");
    command = BT.readStringUntil('\n');
    if (command.equals("/Ardu Start")) {
      search();
    else if (command.equals("/Ardu Reboot")) {
      reboot();
    else if (command.equals("/Ardu Ping Me")) {
      pingconnected();
    else if (command.equals("/Ardu Show Data")) {
      get_data();
      devstate = 5;
    else if (command.equals("/Ardu Rest")) {
      devstate = 5;
    else if (command.equals("/Ardu Name")) {
      BT.println(devname);
      Serial.println(devname);
    else if (command.equals("/Ardu Rover Version")) {
      BT.println(devversion);
      Serial.println(devversion);
    else {
      Serial.println("Invalid command:");
      Serial.println(command);
      Serial.println("");
      BT.println("Invalid command:");
      BT.println(command);
      BT.println("");
//Styles
void title()
  Serial.println("--------------------------------");
  Serial.println("|     ArduDATA Rover 1.3.3     |");
  Serial.println("| Project by Reuben C. Buckley |");
  BT.println("--------------------------------");
  BT.println("|     ArduDATA Rover 1.3.3     |");
  BT.println("| Project by Reuben C. Buckley |");
void initializing()
  Serial.println("________________________________________________________________");
  Serial.println("--------------------------");
  Serial.print("| Initializing");
  Serial.print(".");
  BT.println("________________________________________________________________");
  BT.println("--------------------------");
  BT.print("| Initializing");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.print(".");
  BT.print(".");
  Serial.println(". |");
  Serial.println("");
  BT.println(". |");
  BT.println("");
  //  datalog = SD.open("datalog.txt", FILE_WRITE);
  //  if (datalog)
  //    Serial.println("Logging...");
  unsigned long CurrentTime = millis();
  unsigned long ElapsedTime = CurrentTime - StartTime;
  BT.println(ElapsedTime);
  BT.println("Initialized");
  BT.println("SYS_OK");
  BT.println("Awaiting Command");
  //BT.print("Device_STATE: ");
  Serial.println(ElapsedTime);
  Serial.println("SYS_OK");
  Serial.println("");
  Serial.println("Initialized");
  Serial.print("Device_STATE: ");
  //    datalog.close();
  Serial.println("Datalogged");
  Serial.println("");
  BT.begin(9600);
  title();
  //  SD.begin(3);
  //  if (!SD.begin(3))
  //    Serial.println("SD failed to initiatilze, please check the connection");
  //    while (1);
  //  Serial.println("SD initialized");
  //  if (SD.exists("datalog.txt"))
  //    Serial.print("Found file: ");
  //    Serial.println(datalog);
  //  else {
  //    Serial.print("Creating file: ");
  //  if (datalog)
  //    unsigned long CurrentTime = millis();
  //    unsigned long ElapsedTime = CurrentTime - StartTime;
  //    datalog.println(ElapsedTime);
  //    datalog.println("Log_begin");
  //    Serial.println(ElapsedTime);
  //    Serial.println("Log_begin");
  //    datalog.close();
  //    Serial.println("Datalogged");
  //Set pins as motor outputs
  pinMode(Reset, OUTPUT);
  pinMode(motorPin1, OUTPUT);
  pinMode(motorPin2, OUTPUT);
  pinMode(motorPin3, OUTPUT);
  pinMode(motorPin4, OUTPUT);
  pinMode(EN1, OUTPUT);
  pinMode(EN2, OUTPUT);
  digitalWrite(Reset, LOW);
  irrecv.enableIRIn();
  //irrecv.blink13(true);
  delay(100);                 // Wait for 100 millisecond(s)
  initializing();
  while (BT.available() == 0) { } // There really is nothing between the {} braces
  //if(cmdln == "/")
  commandpromt();
  while (devstate == 1)
    //this will start motors
    Mfwd();
    if (irrecv.decode(&results)) {
      irinput();
      //this will stop motors
      Mstp();
      devstate = 2;
  while (devstate == 2)
    unsigned long ElapsedTime = CurrentTime - DriveTime;
    Serial.print("Driving ");
    Serial.print(ElapsedTime);
    Serial.println("  milliseconds to home location.");
    BT.print("Driving ");
    BT.print(ElapsedTime);
    BT.println("  milliseconds to home location.");
    Serial.println("Turning to go home");
    BT.println("Turning to go home");
    delay(turntime * 180);        //turntime is the trim adjustment for how long it takes the rover to turn 1 degree in it's current configuration
    Serial.println("Homing...");
    BT.println("Homing...");
    Mstp();
    //this will start the motors
    Mfwd();
    Serial.print("Device_STATE:");    //Checks in device state (System heartbeat)
    //BT.print("Device_STATE:");    //Checks in device state (System heartbeat)
    delay(ElapsedTime);           //this will drive the rover in a straight line for the same amount of time it took to get the data
    Serial.println("Homed");
    BT.println("Homed");
    Mstp();
    Serial.println("Resting here for data transfer");
    BT.println("Resting here for data transfer");
    devstate = 3;
  while (devstate == 3)
    commandpromt();             //sets the device to command promt mode
  //while (devstate == 4)           //legacy state, not used from 1.3.1 onwards
  //  Serial.print("Device_STATE:"); //Reads out the data that was found (viewed through serial monitor)
  //  Serial.println(devstate);
  //  Serial.println("Retrieving Latest Data");
  //  delay(500);
  //  if (results.value > 0)
  //    Serial.read();
  //    Serial.println("Data found");
  //    Serial.println(results.value, HEX);
  //  else {
  //    Serial.println("NO_DATA!");
  //  devstate = 5;              //sets the device state to rest mode
  while (devstate == 5)
    Serial.println("Device is at rest");
    Serial.println("press any key to see latest data");
    Serial.println("");
    BT.println("Device is at rest");
    BT.println("Use BT commands to do actions");
    BT.println("");
    delay(5000);
    commandpromt();
    //  if (BT.available())      //Repeats Data readout if something is sent over the serial monitor
    //    BT.read();
    //      Serial.read();
    //    else {
This is the suspect code
can you explain your motor connections?
what are motorPins 1-4 (direction?) and EN pin 1&2?
it looks like the EN pins are set LOW in Mstp(), suggesting that turns them Off. but in Mtrim() called by Mfwd(), the EN pins are set HIGH but quickly set LOW
steering could be implemented by controlling the speed of the motors to each EN pin using analogWrite() to generate a PWM waveform
Mfwd() calls Mtrim() which shuts down the motors after a few milliseconds. You have to call Mfwd() repeatedly to continue to move forward. Add a loop that calls Mfwd() until ElapsedTime is reached.
it's easier to debug code that is developed in stages that are each testable instead of developing code with some end goal in mind that is likely to change
while john and I may have identified the problem, it would be easier if each "command" could be individually exercised and tested, as well as having a program structure that makes it easy to add (and test) new commands. the deiserd end goal then becomes a sequence of sub-commands.
i'm posting a heavily modified version of you code that reorganizes the code to make it more maintainable (readable, debug-able, modify-able) and renamed symbols more conventionally
a significant change is for loop() to check for input and execute a command when received rather that have states check for commands (subtle difference).
i think you'll need to look at the retrace(). it seemed that it took too short a period to turn around. i mapped 4 of the motor pins to LEDs on a multi-function board. i ran start and then retrace thru the serial monitor.
again, i think the code below demonstrates some techniques you may be interested in.
// table driven controller for rover
enum { Off = HIGH, On = LOW };
const char *version = "gc210529b";
const char *name    = "Soil Moisture Puck";
const char *batlvl  = "N/a";
int     devstate = 0;
int     Reset = 8;
int     sensedata = 0;
int     cmdln;
String  command;
const int turntime = 5;          // trims how long rover takes to turn 1 degree
#undef MyHW
#ifdef MyHW
const int motorPin1  = 11;
const int motorPin2  = 5;
const int motorPin3  = 12;
const int motorPin4  = 6;
const int en1 = 10;
const int en2 = 13;
#else
const int en1 = 11;
const int en2 = 12;
#endif
unsigned long StartTime = 0;        // resets the log clock
unsigned long DriveTime = 0;        // resets the Drive clock
const int RECV_PIN = 7;             // defines IR reciver pin
byte outPins [] = { en1, en2, motorPin1, motorPin3 };
#define N_PINS   sizeof (outPins)
char s [80];
// Stop Motors Function
void
mStop (void)
    Serial.println (__func__);
    digitalWrite (motorPin1, LOW);
    digitalWrite (motorPin2, LOW);
    digitalWrite (motorPin3, LOW);
    digitalWrite (motorPin4, LOW);
    digitalWrite (en1, LOW);
    digitalWrite (en2, LOW);
// Drive Forward Function
void
mFor (void)
    digitalWrite (motorPin1, HIGH);
    digitalWrite (motorPin3, HIGH);
    Mtrim ();
// Differential Steering Trim, helps the rover drive straight
void Mtrim (void)
    int right = 10;
    int left = 20;
    delay (1);
    digitalWrite (en1, HIGH);
    digitalWrite (en2, HIGH);
    if (right > left){
        delay (left);
        delay (right - left);
    else if (right == left){
        delay (right);
        delay (left - right);
    else if (right < left){
        delay (right);
// recalls the data collected and displays it over the serial monitor and
// over the bluetooth terminal along with some presets that in future
// could be determined by the Soil moisture puck (name, battery level, etc)
void
getData (void)
    Serial.println ("");
    Serial.println ("Retrieving Latest Data...");
    delay (500);
        Serial.println ("NO_DATA!");
        getName ();
// This function is for the use of advanced data recieving,
// which requires intergers decoded into strings of data.
// Possible future updates will make use of this function
void
getName (void)
// When the rover recieves an IR signal, it runs this function.
void
irinput (void)
    Serial.println (sensedata, HEX);
    Serial.print ("Device_STATE:");
    Serial.println (devstate);
        Serial.read ();
        Serial.println ("Data saved");
// Other than checking to see if the rover is still on talking terms
// with the bluetooth terminal, it doesn't do anything else
void
ping (void)
// Restarts the rover so it can get sent out freash.
// Had issues with this causing a reset when booting as there's
// no way to stop the arduino setting the pins to high breifly on startup,
// hence this is disconnected on the rover and
// only serves to stop the code at the moment.
void
reboot (void)
    delay (1000);
    digitalWrite (Reset, HIGH);
void
retrace (void)
    unsigned long CurrentTime = millis ();
    sprintf (s, "%s: CurrentTime %ld msec, ElapsedTime %ld msec",
        __func__, CurrentTime, ElapsedTime);
    Serial.println (s);
    // turntime is the trim adjustment for how long
    // it takes the rover to turn 1 degree in it's current configuration
    sprintf (s, " %s: turnaround delay, %d msec", __func__, turntime * 180);
    Serial.println (s);
    delay (turntime * 180);
    mStop ();
    sprintf (s, " %s: delay, %d msec", __func__, 1000);
    Serial.println (s);
    delay (1000);
    mFor ();
    // this will drive the rover in a straight line
    // for the same amount of time it took to get the data
    sprintf (s, " %s: retrace %ld msec", __func__, ElapsedTime);
    Serial.println (s);
    delay (ElapsedTime);
    sprintf (s, " %s: stop - home", __func__);
    Serial.println (s);
    mStop ();
// When this is run, all the rover sees is GO GO GO!
// But seriously, this function tells the rover to start searching
// for the soil moisture puck
void
start (void)
    DriveTime = millis ();        // resets the Drive clock
    sprintf (s, "%s: DriverTime %ld msec", __func__, DriveTime);
    Serial.println (s);
    mFor ();
void
ver (void)
    sprintf (s, "%s - %s", name, version);
    Serial.println (s);
void help (void);
struct Cmds_s {
    void (*func) (void);
    const char  *cmd;
} cmds [] = {
    { getData,  "data" },
    { mFor,     "for" },
    { getName,  "name" },
    { ping,     "ping" },
    { mStop,    "stop" },
    { reboot,   "reboot" },
    { retrace,  "retrace" },
    { start,    "start" },
    { ver,      "ver" },
    { help,     "?" },
    { 0,        0     }
void
help (void)
    sprintf (s, " %s:", __func__);
    Serial.println (s);
    for (Cmds_s *p = cmds; p->func; p++)  {
        sprintf (s, "  %s", p->cmd);
        Serial.println (s);
void
getCmd (void)
    static char buf [40];
    static int  idx = 0;
    if (! Serial.available())
        return;                 // no pending input
    char c = Serial.read ();
    if ('\n' != c)  {
        buf [idx++] = c;
        return;                 // incomplete cmd
    if (0 == idx)
        return;                 // empty line
    buf [idx] = 0;
#if 0
        sprintf (s, " %s:  %s - %s", __func__, buf, p->cmd);
        Serial.println (s);
#endif
        if (! strcmp (p->cmd, buf))  {
            idx = 0;
            return p->func ();
    sprintf (s, "%s: %s - not found", __func__, buf);
    Serial.println (s);
void
loop (void)
    getCmd ();
void
setup (void)
    Serial.begin (9600);
    for (unsigned n = 0; n < N_PINS; n++)  {
        digitalWrite (outPins [n], Off);
        pinMode (outPins [n], OUTPUT);
    mStop ();
    ver ();
    help ();
How do I do that?
Thank you so much, this is very helpful!
After the u-turn, at this call, Mfwd();
you never reset devstate back to =1;
