Rowberg's Libraries for MPU-6050 Breakout Board Not Working
I have been having issues with Rowberg's libraries for the MPU-6050 Breakout Board (http://www.ebay.com/itm/MPU-6050-Module-3-Axis-Gyroscope-Acce-lerometer-for-Arduino-Power-supply-3v-5v-/140843435041?pt=LH_DefaultDomain_0&hash=item20caec4421).
In particular, when I run https://github.com/jrowberg/i2cdevlib/blob/master/Arduino/MPU6050/Examples/MPU6050_raw/MPU6050_raw.ino the Serial Port Monitor outputs strange, incomprehensible symbols.
Here is a sample:
Our wiring is as follows:
VCC - 3.3V
GND - GND
SDA - Analog A4
SCL - Analog A5
INT - Pin 2
Any advice on this matter would be greatly appreciated.
ARDUINputOutput:
Here is a sample:
Look in the bottom right of your serial monitor, where the speed is 9600. Now look a the sketch you referenced:
Serial.begin(38400);
So, set your serial monitor to 38400.
Thank you! This works.
