I have connected my RP2040 with a Polar H10 heartbeat sensor using the code below.
#include <ArduinoBLE.h>
while (!Serial);
// begin initialization
if (!BLE.begin()) {
Serial.println("starting BLE failed!");
while (1);
Serial.println("BLE Central - Peripheral Explorer");
// start scanning for peripherals
BLE.scan();
// check if a peripheral has been discovered
BLEDevice peripheral = BLE.available();
if (peripheral) {
// discovered a peripheral, print out address, local name, and advertised service
Serial.print("Found ");
Serial.print(peripheral.address());
Serial.print(" '");
Serial.print(peripheral.localName());
Serial.print("' ");
Serial.print(peripheral.advertisedServiceUuid());
// see if peripheral is a LED
if (peripheral.localName() == "Polar H10 9EF6E824") {
// stop scanning
BLE.stopScan();
explorerPeripheral(peripheral);
// peripheral disconnected, we are done
while (1) {
// do nothing
void explorerPeripheral(BLEDevice peripheral) {
// connect to the peripheral
Serial.println("Connecting ...");
if (peripheral.connect()) {
Serial.println("Connected");
Serial.println("Failed to connect!");
return;
// discover peripheral attributes
Serial.println("Discovering attributes ...");
if (peripheral.discoverAttributes()) {
Serial.println("Attributes discovered");
Serial.println("Attribute discovery failed!");
peripheral.disconnect();
return;
// read and print device name of peripheral
Serial.print("Device name: ");
Serial.println(peripheral.deviceName());
Serial.print("Appearance: 0x");
Serial.println(peripheral.appearance(), HEX);
// loop the services of the peripheral and explore each
for (int i = 0; i < peripheral.serviceCount(); i++) {
BLEService service = peripheral.service(i);
exploreService(service);
// we are done exploring, disconnect
// Serial.println("Disconnecting ...");
//peripheral.disconnect();
// Serial.println("Disconnected");
void exploreService(BLEService service) {
// print the UUID of the service
Serial.print("Service ");
Serial.println(service.uuid());
// loop the characteristics of the service and explore each
for (int i = 0; i < service.characteristicCount(); i++) {
BLECharacteristic characteristic = service.characteristic(i);
exploreCharacteristic(characteristic);
void exploreCharacteristic(BLECharacteristic characteristic) {
// print the UUID and properties of the characteristic
Serial.print("\tCharacteristic ");
Serial.print(characteristic.uuid());
Serial.print(", properties 0x");
Serial.print(characteristic.properties(), HEX);
// check if the characteristic is readable
if (characteristic.canRead()) {
// read the characteristic value
characteristic.read();
if (characteristic.valueLength() > 0) {
// print out the value of the characteristic
Serial.print(", value 0x");
printData(characteristic.value(), characteristic.valueLength());
// loop the descriptors of the characteristic and explore each
for (int i = 0; i < characteristic.descriptorCount(); i++) {
BLEDescriptor descriptor = characteristic.descriptor(i);
exploreDescriptor(descriptor);
void exploreDescriptor(BLEDescriptor descriptor) {
// print the UUID of the descriptor
Serial.print("\t\tDescriptor ");
Serial.print(descriptor.uuid());
// read the descriptor value
descriptor.read();
// print out the value of the descriptor
printData(descriptor.value(), descriptor.valueLength());
void printData(const unsigned char data[], int length) {
for (int i = 0; i < length; i++) {
unsigned char b = data[i];
if (b < 16) {
Serial.print("0");
Serial.print(b, HEX);
When I connect with the sensor, the result is as follows:
11:01:56.873 -> BLE Central - Peripheral Explorer
11:01:57.106 -> Found ea:1f:b5:f6:9c:5c 'Polar H10 9EF6E824' 180d
11:01:57.106 -> Connecting ...
11:01:57.624 -> Connected
11:01:57.624 -> Discovering attributes ...
11:02:00.347 -> Attributes discovered
11:02:00.347 ->
11:02:00.347 -> Device name: Polar H10 9EF6E824
11:02:00.347 -> Appearance: 0x0
11:02:00.347 ->
11:02:00.347 -> Service 1800
11:02:00.347 -> Characteristic 2a00, properties 0x2, value 0x506F6C617220483130203945463645383234
11:02:00.394 -> Descriptor 2803, value 0x020500012A
11:02:00.439 -> Descriptor 2a01, value 0x4103
11:02:00.439 -> Characteristic 2a01, properties 0x2, value 0x4103
11:02:00.486 -> Descriptor 2803, value 0x020700042A
11:02:00.533 -> Descriptor 2a04, value 0xF900900101005802
11:02:00.579 -> Characteristic 2a04, properties 0x2, value 0xF900900101005802
11:02:00.627 -> Descriptor 2803, value 0x020900A62A
11:02:00.627 -> Descriptor 2aa6, value 0x01
11:02:00.673 -> Characteristic 2aa6, properties 0x2, value 0x01
11:02:00.720 -> Service 1801
11:02:00.720 -> Characteristic 2a05, properties 0x20
11:02:00.720 -> Descriptor 2902, value 0x0000
11:02:00.720 -> Service 180d
11:02:00.720 -> Characteristic 2a37, properties 0x10
11:02:00.767 -> Descriptor 2803, value 0x021300382A
11:02:00.815 -> Descriptor 2a38, value 0x01
11:02:00.861 -> Characteristic 2a38, properties 0x2, value 0x01
11:02:00.861 -> Service 181c
11:02:00.861 -> Characteristic 2a99, properties 0xA
11:02:00.908 -> Descriptor 2803, value 0x0218009A2A
11:02:00.955 -> Descriptor 2a9a, value 0x
11:02:00.955 -> Characteristic 2a9a, properties 0x2
11:02:01.002 -> Descriptor 2803, value 0x281A009F2A
11:02:01.050 -> Descriptor 2b9f, value 0x
11:02:01.050 -> Characteristic 2a9f, properties 0x28
11:02:01.050 -> Descriptor 2902, value 0x0000
11:02:01.097 -> Descriptor 2803, value 0x8A1D008A2A
11:02:01.143 -> Descriptor 2a8a, value 0x
11:02:01.190 -> Characteristic 2a8a, properties 0x8A
11:02:01.237 -> Descriptor 2900, value 0x0100
11:02:01.237 -> Descriptor 2803, value 0x8A2000902A
11:02:01.284 -> Descriptor 2a90, value 0x
11:02:01.331 -> Characteristic 2a90, properties 0x8A
11:02:01.331 -> Descriptor 2900, value 0x0100
11:02:01.378 -> Descriptor 2803, value 0x0A2300802A
11:02:01.425 -> Descriptor 2a80, value 0x
11:02:01.425 -> Characteristic 2a80, properties 0xA
11:02:01.471 -> Descriptor 2803, value 0x0A25008C2A
11:02:01.518 -> Descriptor 2a8c, value 0x
11:02:01.565 -> Characteristic 2a8c, properties 0xA
11:02:01.612 -> Descriptor 2803, value 0x0A2700982A
11:02:01.612 -> Descriptor 2a98, value 0x
11:02:01.659 -> Characteristic 2a98, properties 0xA
11:02:01.706 -> Descriptor 2803, value 0x0A29008E2A
11:02:01.706 -> Descriptor 2a8e, value 0x
11:02:01.752 -> Characteristic 2a8e, properties 0xA
11:02:01.799 -> Descriptor 2803, value 0x0A2B00A22A
11:02:01.846 -> Descriptor 2aa2, value 0x
11:02:01.892 -> Characteristic 2aa2, properties 0xA
11:02:01.892 -> Service 180a
11:02:01.892 -> Characteristic 2a29, properties 0x2, value 0x506F6C617220456C656374726F204F7900
11:02:01.938 -> Descriptor 2803, value 0x023000242A
11:02:01.985 -> Descriptor 2a24, value 0x48313000
11:02:02.032 -> Characteristic 2a24, properties 0x2, value 0x48313000
11:02:02.032 -> Descriptor 2803, value 0x023200252A
11:02:02.079 -> Descriptor 2a25, value 0x394546364538323400
11:02:02.127 -> Characteristic 2a25, properties 0x2, value 0x394546364538323400
11:02:02.127 -> Descriptor 2803, value 0x023400272A
11:02:02.173 -> Descriptor 2a27, value 0x30303736303639302E303300
11:02:02.173 -> Characteristic 2a27, properties 0x2, value 0x30303736303639302E303300
11:02:02.220 -> Descriptor 2803, value 0x023600262A
11:02:02.267 -> Descriptor 2a26, value 0x352E302E3000
11:02:02.267 -> Characteristic 2a26, properties 0x2, value 0x352E302E3000
11:02:02.313 -> Descriptor 2803, value 0x023800282A
11:02:02.359 -> Descriptor 2a28, value 0x332E312E3100
11:02:02.406 -> Characteristic 2a28, properties 0x2, value 0x332E312E3100
11:02:02.406 -> Descriptor 2803, value 0x023A00232A
11:02:02.453 -> Descriptor 2a23, value 0xE8F69EFEFF1A9EA0
11:02:02.500 -> Characteristic 2a23, properties 0x2, value 0xE8F69EFEFF1A9EA0
11:02:02.500 -> Service 180f
I want the program to return values for heart rate. Is there some changes I can make in the program, or something in the results that represents this?
