I would like to use an RP Lidra for object detection. I have built a vehicle lift and would like to use the Lidar to take a snapshot of the area under the lift as it goes up. When the lift is ready to be lowered I would like to take another snapshot then compare the two shots to see if anything has been left in the area under the lift. I would like to do a comparison because there will be the legs of the lift in the range of the lidar but these will not interfere with the operation.
I can get a serial stream from the Lidar give angles and distance but what do I do with it after that?
I think I need to put this data into some .sort of an array but not totally sure how to do this.
Yes, You did tell "vehicle lift"..... I made up another picture in my mind.
You aim for a vision system. That calls for quite some memory and also processor power.
That is not really my best subject.
Search for face recognition, vision system, among the projects here.
