RP2040 bad tempo value reading external MIDI clock
Hi guys,
I'm developing sort of a synth and it needs MIDI input.
I use this library GitHub - FortySevenEffects/arduino_midi_library: MIDI for Arduino that works pretty well on rp2040.
I also use the PIO (platformIO) framework for developing.
I need to monitor the tempo sent by DAWs or external gear via DIN, the MIDI works nicely on the two MIDI inputs (CC messages, notes on, notes off) but when I need to monitor the tempo, I get a constant value of 60.
I think it's because I read the Midi data in the loop and not in an interrupt, but I'm not sure.
My code :
main.cpp
#include <MidiInput.h>
MidiInput midiInput = MidiInput();
void setup(){
  midiInput.configure();
void loop(){
    static unsigned long prev = millis();
    unsigned long now = millis();
    if (now - prev > 4)
        midiInput.read())
        prev = now;
MidiInput.cpp
#include <Adafruit_TinyUSB.h>
#include <MIDI.h>
using namespace midi;
// USB MIDI_DIN object
Adafruit_USBD_MIDI usb_midi;
// Create a new instance of the Arduino MIDI_DIN Library,
// and attach usb_midi as the transport.
MIDI_CREATE_INSTANCE(Adafruit_USBD_MIDI, usb_midi, MIDI_USB);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI_DIN)
void MidiInput::configure()
    MIDI_USB.turnThruOff();
    MIDI_DIN.turnThruOff();
    MIDI_USB.begin(midiChannel);
    MIDI_DIN.begin(midiChannel);
bool MidiInput::read()
    bool beenUpdated = 0;
    if (mode)
        if (MIDI_USB.read())
        if (MIDI_DIN.read())
    switch (mode ? MIDI_USB.getType() : MIDI_DIN.getType())
    case midi::Clock:
        static int ticks = 0;
        static unsigned long lastClock = 0;
        unsigned long clock = millis();
        if (ticks++ == 24)
            unsigned long ppqTime = lastClock - clock;
            sequencer.incrementSeqIndex();
            bpm = 60, 000 / ppqTime;
            lastClock = clock;
            ticks = 0;
    return beenUpdated;
MidiInput.h
class MidiInput
public:
    // 0 DIN, 1 USB
    bool mode = false;
    MidiInput();
    int midiChannel = 0;
    unsigned long bpm = 0;
    void configure();
    bool read();
C++ uses a decimal point, not a comma.
Google for "comma operator C++".
if (now - prev > 4)
Why?
Oops you are right, it's better with 60'000
Why?
Because I have several other processing and it's responding better with this little delay, maybe I'm wrong to do this ?
With this code
case midi::Clock:
        if (ticks++ >= 24)
            unsigned long noteTime = lastClock - clock;
            bpm = 60000 / noteTime;
            Serial.println(noteTime);
            lastClock = clock;
            ticks = 0;
I got a result noteTime(ppq) of
4294966875
It doesn't seems right
