Changing pins of the SPI seems not be working. The code below is the example sketch WebClient given by the IDE (Examples > Ethernet > WebClient) i did remove the contents of the loop as those are unecessary at the moment. As i was investigating what is the cause why im not able to connect the internet, i found that the SPI signals does not look right.
#include <SPI.h>
#include <Ethernet.h>
byte mac[] = { 0xDE, 0xAD, 0xBE, 0xEF, 0xFE, 0xED };
IPAddress server(172, 217, 24, 100); // numeric IP for Google (no DNS)
IPAddress ip(192, 168, 1, 177);
IPAddress myDns(192, 168, 1, 1);
EthernetClient client;
unsigned long beginMicros, endMicros;
unsigned long byteCount = 0;
bool printWebData = true; // set to false for better speed measurement
SPI.setRX(0);
SPI.setTX(3);
SPI.setSCK(2);
SPI.setCS(1);
// start the Ethernet connection:
Serial.println("Initialize Ethernet with DHCP:");
if (Ethernet.begin(mac) == 0) {
Serial.println("Failed to configure Ethernet using DHCP");
// Check for Ethernet hardware present
if (Ethernet.hardwareStatus() == EthernetNoHardware) {
Serial.println("Ethernet shield was not found. Sorry, can't run without hardware. :(");
while (true) {
delay(1); // do nothing, no point running without Ethernet hardware
if (Ethernet.linkStatus() == LinkOFF) {
Serial.println("Ethernet cable is not connected.");
// try to congifure using IP address instead of DHCP:
Ethernet.begin(mac, ip, myDns);
Serial.print(" DHCP assigned IP ");
Serial.println(Ethernet.localIP());
I have a scope shot of the 4 SPI pins, This is directly taken on the legs of the W5500 module. The Chip select pin seem not to be pulling low, thus the device is not responding.
To verify that it is not hardware base related. I have tried to run it with Arduino Mbed OS RP2040 board v2.5.2. The signals makes much more like a SPI transaction. (Note: i have modified the pin_arduino.h of the Mbed OS to use MOSI=3 , MISO=0, SCLK=2, CS =1 )
Arduino IDE version 1.8.16
Arduino Core - Raspberry Pi RP2040 Boards v 1.9.6 - Raspberry pi pico
Physical Board - Raspberry Pi Pico
Ethernet Module - W5500
