RP2040 Keylogger?
Hey everyone,
I recently got a Waveshare RP2040-One which has a built-in male USB-A connector. I attached a female USB connector to it and using Examples -> AdafruitTinyUSB -> DualRole -> HID -> hid_remapper.ino, I got it to switch the case of keystrokes coming from a keyboard plugged into the USB connector.
What I want to be able to do is create a program that can read keystrokes, convert them to text, and log it to a file stored in the flash memory (if that's possible), while also passing the keystrokes to the connected computer.
Here's the code that changes the case of keystrokes (not my code):
 Adafruit invests time and resources providing this open source code,
 please support Adafruit and open-source hardware by purchasing
 products from Adafruit!
 MIT license, check LICENSE for more information
 Copyright (c) 2019 Ha Thach for Adafruit Industries
 All text above, and the splash screen below must be included in
 any redistribution
/* This example demonstrates use of both device and host, where
 * - Device run on native usb controller (controller0)
 * - Host run on bit-banging 2 GPIOs with the help of Pico-PIO-USB library (controller1)
 * Example sketch receive keyboard report from host interface (from e.g consumer keyboard)
 * and remap it to another key and send it via device interface (to PC). For simplicity,
 * this example only toggle shift key to the report, effectively remap:
 * - all character key <-> upper case
 * - number <-> its symbol (with shift)
 * Requirements:
 * - [Pico-PIO-USB](https://github.com/sekigon-gonnoc/Pico-PIO-USB) library
 * - 2 consecutive GPIOs: D+ is defined by PIN_USB_HOST_DP, D- = D+ +1
 * - Provide VBus (5v) and GND for peripheral
 * - CPU Speed must be either 120 or 240 Mhz. Selected via "Menu -> CPU Speed"
// pio-usb is required for rp2040 host
#include "pio_usb.h"
#include "Adafruit_TinyUSB.h"
// Pin D+ for host, D- = D+ + 1
#ifndef PIN_USB_HOST_DP
#define PIN_USB_HOST_DP       10
#endif
// Pin for enabling Host VBUS. comment out if not used
#ifndef PIN_5V_EN
#define PIN_5V_EN        18
#endif
#ifndef PIN_5V_EN_STATE
#define PIN_5V_EN_STATE  1
#endif
// Language ID: English
#define LANGUAGE_ID 0x0409
// USB Host object
Adafruit_USBH_Host USBHost;
// HID report descriptor using TinyUSB's template
// Single Report (no ID) descriptor
uint8_t const desc_hid_report[] =
  TUD_HID_REPORT_DESC_KEYBOARD()
// USB HID object. For ESP32 these values cannot be changed after this declaration
// desc report, desc len, protocol, interval, use out endpoint
Adafruit_USBD_HID usb_hid(desc_hid_report, sizeof(desc_hid_report), HID_ITF_PROTOCOL_KEYBOARD, 2, false);
// Setup and Loop on Core0
  usb_hid.begin();
  while ( !Serial ) delay(10);   // wait for native usb
  Serial.println("TinyUSB Host HID Remap Example");
// Setup and Loop on Core1
void setup1() {
  //while ( !Serial ) delay(10);   // wait for native usb
  Serial.println("Core1 setup to run TinyUSB host with pio-usb");
  // Check for CPU frequency, must be multiple of 120Mhz for bit-banging USB
  uint32_t cpu_hz = clock_get_hz(clk_sys);
  if ( cpu_hz != 120000000UL && cpu_hz != 240000000UL ) {
    Serial.printf("Error: CPU Clock = %lu, PIO USB require CPU clock must be multiple of 120 Mhz\r\n", cpu_hz);
    Serial.printf("Change your CPU Clock to either 120 or 240 Mhz in Menu->CPU Speed \r\n");
    while(1) delay(1);
#ifdef PIN_5V_EN
  pinMode(PIN_5V_EN, OUTPUT);
  digitalWrite(PIN_5V_EN, PIN_5V_EN_STATE);
#endif
  pio_usb_configuration_t pio_cfg = PIO_USB_DEFAULT_CONFIG;
  pio_cfg.pin_dp = PIN_USB_HOST_DP;
#if defined(ARDUINO_RASPBERRY_PI_PICO_W)
  // For pico-w, PIO is also used to communicate with cyw43
  // Therefore we need to alternate the pio-usb configuration
  // details https://github.com/sekigon-gonnoc/Pico-PIO-USB/issues/46
  pio_cfg.sm_tx      = 3;
  pio_cfg.sm_rx      = 2;
  pio_cfg.sm_eop     = 3;
  pio_cfg.pio_rx_num = 0;
  pio_cfg.pio_tx_num = 1;
  pio_cfg.tx_ch      = 9;
#endif
  USBHost.configure_pio_usb(1, &pio_cfg);
  // run host stack on controller (rhport) 1
  // Note: For rp2040 pico-pio-usb, calling USBHost.begin() on core1 will have most of the
  // host bit-banging processing works done in core1 to free up core0 for other works
  USBHost.begin(1);
void loop1()
  USBHost.task();
// Invoked when device with hid interface is mounted
// Report descriptor is also available for use.
// tuh_hid_parse_report_descriptor() can be used to parse common/simple enough
// descriptor. Note: if report descriptor length > CFG_TUH_ENUMERATION_BUFSIZE,
// it will be skipped therefore report_desc = NULL, desc_len = 0
void tuh_hid_mount_cb(uint8_t dev_addr, uint8_t instance, uint8_t const *desc_report, uint16_t desc_len) {
  (void)desc_report;
  (void)desc_len;
  uint16_t vid, pid;
  tuh_vid_pid_get(dev_addr, &vid, &pid);
  Serial.printf("HID device address = %d, instance = %d is mounted\r\n", dev_addr, instance);
  Serial.printf("VID = %04x, PID = %04x\r\n", vid, pid);
  uint8_t const itf_protocol = tuh_hid_interface_protocol(dev_addr, instance);
  if (itf_protocol == HID_ITF_PROTOCOL_KEYBOARD) {
    Serial.printf("HID Keyboard\r\n");
    if (!tuh_hid_receive_report(dev_addr, instance)) {
      Serial.printf("Error: cannot request to receive report\r\n");
// Invoked when device with hid interface is un-mounted
void tuh_hid_umount_cb(uint8_t dev_addr, uint8_t instance) {
  Serial.printf("HID device address = %d, instance = %d is unmounted\r\n", dev_addr, instance);
void remap_key(hid_keyboard_report_t const* original_report, hid_keyboard_report_t* remapped_report)
  memcpy(remapped_report, original_report, sizeof(hid_keyboard_report_t));
  // only remap if not empty report i.e key released
  for(uint8_t i=0; i<6; i++) {
    if (remapped_report->keycode[i] != 0) {
      // Note: we ignore right shift here
      remapped_report->modifier ^= KEYBOARD_MODIFIER_LEFTSHIFT;
// Invoked when received report from device via interrupt endpoint
void tuh_hid_report_received_cb(uint8_t dev_addr, uint8_t instance, uint8_t const *report, uint16_t len) {
  if ( len != 8 ) {
    Serial.printf("report len = %u NOT 8, probably something wrong !!\r\n", len);
  }else {
    hid_keyboard_report_t remapped_report;
    remap_key((hid_keyboard_report_t const*) report, &remapped_report);
    // send remapped report to PC
    // NOTE: for better performance you should save/queue remapped report instead of
    // blocking wait for usb_hid ready here
    while ( !usb_hid.ready() ) {
      yield();
    usb_hid.sendReport(0, &remapped_report, sizeof(hid_keyboard_report_t));
  // continue to request to receive report
I'm not looking to do any harm with this, it's just for fun.
Thank you to anyone who can point me in the right direction!
