Ok,
So i was thinking why not make a interacticve RPG board for my RPG group?
simply put, i want to make a board with squares.
These squares counts as both mesureing distances and positioning for our characters.
i would allso like to make characters that acts with the board, so basicly an interactive board.
If i put a character down on a square i want that square to light up.
Allso i want the board to reqognize what character it is. ( this so i can store information about diffrent characters and monsters and so on)
I want the board to be able to be set to display values stored to these characters in form of squares that perticulair character can walk/ shoot/ hit.
I started off in the touch department after seeing videos of the Sparkfun touch sensor and figured out we have 580 squares on our whiteboard we use atm to plan moves and i would require a lot of input expansion and 49 of the sparkfun sensors.... so this wasnt economic and had to be a better way of doing.
(allso tought RFID tag tech would be cool... but yet again ite expensive (would be cool to store data easely))
Then i remembered about a university touch panel project useing lazers to specify where on the panel you are pokeing and maybe that would be something... but i allso tought if i have a lot of characters close togheter this wouldnt work.
Then i read about the ability to use one of the arduinos analog pins to act like a Ohm meter, would i just be able to put diffrent ammounts of resistance into 3D printed characters? and then have a metallic contact plate at bottom to respond with a contact plate at the center of one of the squares on the board and then let the arduino distinguish between diffrent characters that way, allso lighting up that section.
Anyone have any great ideas or feedback( make me think and rethink this)?
Let the tinkering begin!
Not if you make your own readers like this project of mine.
http://www.thebox.myzen.co.uk/Hardware/RFID_Sequencer.html
I think that would not work so well. When I have tried this then the pressure on the piece between the two contacts is vital. You could possibly embed a magnet to act as a bit of a clamp but it is still touch and go. I did try with conductive paint on the base of pieces just to detect them, not to differentiate between them, work is still ongoing on this.
Have you seen the Reactable table?
That uses a TV camera underneath a table looking at patterns on the base of objects. I think that offers the best way forward for your project. Mind you it is not an Arduino project as you need some image processing and data projection.
Grumpy_Mike:
Cool! Whats the aproximate production cost of 1 unit? as i will be needing 580...
Grumpy_Mike:
Will allso test a few diffrent connections with this, starting with a simple Breadboard like unit, 2 female pin's submerged in the squares and 2 male pins on the figureines (obviously this sint what i want at end but it makes me able to forward other parts of the project allso)
Grumpy_Mike:
http://www.reactable.com/
Yes! ive seen it, and allso know people who made games based on it, i was thinking of a more "simple solution" with a easy fabrication method and modding oportunities and maybe allso beeing able to relocate it with ease.
But i will explore this option further.
About $0.50.
So it will be costing you money then. Anything times 580 cost a lot.
Why not make each piece smart - plug one on, it connects power & gnd, processor queries it for its I2C address or something.
I2C support 128 addresses, so setup 6 or 8 areas to read from.
The "reactable" suggestion Mike made earlier would be the way I'd go.
It's really "reacTIVision" that you're looking for; it's a Windows/Linux daemon that interfaces with a camera and spits out the coordinates of every fiducial marker it has in its view. Putting that another way, you'd print out and stick the little fiducial markers on the bottom of your figurines and, using a camera located under your clear play work surface, reacTIVision would tell you where they are and what direction they're facing. reacTIVision uses the TUIO protocol; there are APIs available for just about every programming language. A Raspberry Pi has enough computing power for the task.
The touch-sensitive thing that the "reactable" does is a trickier problem; it requires a more carefully designed surface and IR edge lighting. I'd suggest skipping that part for a first iteration; you can more easily design your interface just using additional fiducial markers to control panning the field or such.
Grumpy_Mike:
About $0.50.
Excelent!
Grumpy_Mike:
You are totaly right! and ive decided to make a prototype with these.
CrossRoads:
YES! this is brilliant, and maybe i could combine it with Grympy_Mike's rfid suggestion for a finished prototype.
Chagrin:
Well yes, and i did eknowledge this when Grumpy_Mike brought it up, but the issue im faceing is the fact that that the board i want to make and the reacttable are setup for two totally diffrent dimentions, the react table like designs i could find all rely on distance of the camera and the interactive surface, therefore i want to distinguish the "board" and "table" as the design i want would make it much more portable. something in the likes of a clumsy "foldeble chess" kind of design, but not an entire table atleast.
