RPI + Arduino I2C lock up
Hey guys,
I used to have a master Arduino control 5 to 10 other Arduinos and communicate through I2C without much issue. The master constantly wrote 2 bytes, waited 2 milliseconds, and then read the results.
Recently I decided to switch the master to Raspberry pi. I ported the code over and tested I2C with i2cdetect and by testing it through a simple code. It worked and I was able to send and receive data.
The issue I'm having is that if I read a bunch of times the Arduino will lock up. I even lowered my main loop frequency to 50 Hz and it still often fails to write to the I2C and locks up. I'm attaching a simplified snippet of my code on raspberry pi just as a reference. I know that with Arduino I had to put a 2 milliseconds delay or the data would not be reliable, but I don't have such timer on raspberry pi anymore. Would that be the culprit? Has anybody else experienced something similar?
Thanks in advance,
int main(void)
        //-------------- OPEN THE I2C BUS--------------------------
        char *filename = (char*)"/dev/i2c-1";
        if((file_i2c = open(filename, O_RDWR))< 0 ){
                //ERROR HANDLING: you can check errno to see what went wrong;
                cout << "Failed to open the i2c bus" << endl;
                return 0;
        while(1){
		if (loopTime.check()) {  // A timer class to make sure that it only runs every so often
                         loopTime.reset();
                        cout << sendCmd_d(0x03, 40, 42);
        return 0;
float sendCmd_d(uint8_t SlaveDeviceID, uint8_t cmd1, uint8_t cmd2) {
        // Check to see if you can gain access to the I2C port
        if (ioctl(file_i2c, I2C_SLAVE, SlaveDeviceID) < 0){
                cout << "Failed to acquire bus access and/or talk to slave" << endl;
        uint8_t buffer[2] = {0};
        buffer[0] = cmd1;
        buffer[1] = cmd2;
        uint8_t length = 2;        //<<<<< Number of bytes to write
        if (write(file_i2c, buffer, length) != length){                    // write() returns the number of bytes actually written, if it doesn't match then an error occurred (e.g. no response from the device)
        // ERROR HANDLING: i2c transaction failed
                cout << "Failed to write to the i2c bus " << SlaveDeviceID << endl;
	 // GET RESPONSE
	if (cmd1 == get_info_cmd || cmd1 == get_pos_cmd) {
		length = sizeof(float);
		float2byte_t data;
                if (read(file_i2c, data.b  , length) != length){              // read() returns the number of bytes actually read, if it doesn't match then an error occurred (e.g. no response from the device)
                        //ERROR HANDLING: i2c transaction failed
                        cout << " Failed to read from the i2c bus" <<SlaveDeviceID << endl;
                        return data.f;
	return 0;
Is there a usleep() function for the RaspBerry Pi? It's quite standard C in the Linux world.
