RPM 2 LED (Serial monitor)
Hallo alles miteinander ich habe hier ein Projekt den ich irgendwie zusammen gebaut habe, aber ich schaffe es nicht 2 LED, ihre Funktion zu erledigen.
  1. LED (Grün) Wenn es unter einem bestimmten Limit liegt soll die LED leuchten
  2. LED (Rot) Wenn es über dem bestimmten Limit liegt soll die LED leuchten
Meine frage wäre wo genau soll ich diese Funktion in mein Code reinfügen und wie Schreibt man diese Funktion richtig , weil ich habe schön mehr mal versucht aber entwider schreibe ich des falsch oder an falschen ort.
CODE: ```cpp
// Calibration:
const byte PulsesPerRevolution = 2; // Set how many pulses there are on each revolution. Default: 2.
// If the period between pulses is too high, or even if the pulses stopped, then we would get stuck showing the
// last value instead of a 0. Because of this we are going to set a limit for the maximum period allowed.
// If the period is above this value, the RPM will show as 0.
// The higher the set value, the longer lag/delay will have to sense that pulses stopped, but it will allow readings
// at very low RPM.
// Setting a low value is going to allow the detection of stop situations faster, but it will prevent having low RPM readings.
// The unit is in microseconds.
const unsigned long ZeroTimeout = 100000; // For high response time, a good value would be 100000.
// For reading very low RPM, a good value would be 300000.
// Calibration for smoothing RPM:
const byte numReadings = 2; // Number of samples for smoothing. The higher, the more smoothing, but it's going to
// react slower to changes. 1 = no smoothing. Default: 2.
// Variables:
volatile unsigned long LastTimeWeMeasured; // Stores the last time we measured a pulse so we can calculate the period.
volatile unsigned long PeriodBetweenPulses = ZeroTimeout+1000; // Stores the period between pulses in microseconds.
// It has a big number so it doesn't start with 0 which would be interpreted as a high frequency.
volatile unsigned long PeriodAverage = ZeroTimeout+1000; // Stores the period between pulses in microseconds in total, if we are taking multiple pulses.
unsigned long FrequencyRaw; // Calculated frequency, based on the period. This has a lot of extra decimals without the decimal point.
unsigned long FrequencyReal; // Frequency without decimals.
unsigned long RPM; // Raw RPM without any processing.
unsigned int PulseCounter = 1; // Counts the amount of pulse readings we took so we can average multiple pulses before calculating the period.
unsigned long PeriodSum; // Stores the summation of all the periods to do the average.
unsigned long LastTimeCycleMeasure = LastTimeWeMeasured; // Stores the last time we measure a pulse in that cycle.
// We need a variable with a value that is not going to be affected by the interrupt
// because we are going to do math and functions that are going to mess up if the values
// changes in the middle of the cycle.
unsigned long CurrentMicros = micros(); // Stores the micros in that cycle.
// We get the RPM by measuring the time between 2 or more pulses so the following will set how many pulses to
// take before calculating the RPM. 1 would be the minimum giving a result every pulse, which would feel very responsive
// even at very low speeds but also is going to be less accurate at higher speeds.
// With a value around 10 you will get a very accurate result at high speeds, but readings at lower speeds are going to be
// farther from eachother making it less "real time" at those speeds.
// There's a function that will set the value depending on the speed so this is done automatically.
unsigned int AmountOfReadings = 1;
unsigned int ZeroDebouncingExtra; // Stores the extra value added to the ZeroTimeout to debounce it.
// The ZeroTimeout needs debouncing so when the value is close to the threshold it
// doesn't jump from 0 to the value. This extra value changes the threshold a little
// when we show a 0.
// Variables for smoothing tachometer:
unsigned long readings[numReadings]; // The input.
unsigned long readIndex; // The index of the current reading.
unsigned long total; // The running total.
unsigned long average; // The RPM value after applying the smoothing.
void setup() // Start of setup:
Serial.begin(9600); // Begin serial communication.
attachInterrupt(digitalPinToInterrupt(2), Pulse_Event, RISING); // Enable interruption pin 2 when going from LOW to HIGH.
delay(1000); // We sometimes take several readings of the period to average. Since we don't have any readings
// stored we need a high enough value in micros() so if divided is not going to give negative values.
// The delay allows the micros() to be high enough for the first few cycles.
} // End of setup.
void loop() // Start of loop:
// The following is going to store the two values that might change in the middle of the cycle.
// We are going to do math and functions with those values and they can create glitches if they change in the
// middle of the cycle.
LastTimeCycleMeasure = LastTimeWeMeasured; // Store the LastTimeWeMeasured in a variable.
CurrentMicros = micros(); // Store the micros() in a variable.
// CurrentMicros should always be higher than LastTimeWeMeasured, but in rare occasions that's not true.
// I'm not sure why this happens, but my solution is to compare both and if CurrentMicros is lower than
// LastTimeCycleMeasure I set it as the CurrentMicros.
// The need of fixing this is that we later use this information to see if pulses stopped.
if(CurrentMicros < LastTimeCycleMeasure)
LastTimeCycleMeasure = CurrentMicros;
// Calculate the frequency:
FrequencyRaw = 10000000000 / PeriodAverage; // Calculate the frequency using the period between pulses.
// Detect if pulses stopped or frequency is too low, so we can show 0 Frequency:
if(PeriodBetweenPulses > ZeroTimeout - ZeroDebouncingExtra || CurrentMicros - LastTimeCycleMeasure > ZeroTimeout - ZeroDebouncingExtra)
{ // If the pulses are too far apart that we reached the timeout for zero:
FrequencyRaw = 0; // Set frequency as 0.
ZeroDebouncingExtra = 2000; // Change the threshold a little so it doesn't bounce.
ZeroDebouncingExtra = 0; // Reset the threshold to the normal value so it doesn't bounce.
FrequencyReal = FrequencyRaw / 10000; // Get frequency without decimals.
// This is not used to calculate RPM but we remove the decimals just in case
// you want to print it.
// Calculate the RPM:
RPM = FrequencyRaw / PulsesPerRevolution * 60; // Frequency divided by amount of pulses per revolution multiply by
// 60 seconds to get minutes.
RPM = RPM / 10000; // Remove the decimals.
// Smoothing RPM:
total = total - readings[readIndex]; // Advance to the next position in the array.
readings[readIndex] = RPM; // Takes the value that we are going to smooth.
total = total + readings[readIndex]; // Add the reading to the total.
readIndex = readIndex + 1; // Advance to the next position in the array.
if (readIndex >= numReadings) // If we're at the end of the array:
readIndex = 0; // Reset array index.
// Calculate the average:
average = total / numReadings; // The average value it's the smoothed result.
// Print information on the serial monitor:
// Comment this section if you have a display and you don't need to monitor the values on the serial monitor.
// This is because disabling this section would make the loop run faster.
Serial.print("Period: ");
Serial.print(PeriodBetweenPulses);
Serial.print("\tReadings: ");
Serial.print(AmountOfReadings);
Serial.print("\tFrequency: ");
Serial.print(FrequencyReal);
Serial.print("\tRPM: ");
Serial.print(RPM);
Serial.print("\tTachometer: ");
Serial.println(average);
} // End of loop.
void Pulse_Event() // The interrupt runs this to calculate the period between pulses:
PeriodBetweenPulses = micros() - LastTimeWeMeasured; // Current "micros" minus the old "micros" when the last pulse happens.
// This will result with the period (microseconds) between both pulses.
// The way is made, the overflow of the "micros" is not going to cause any issue.
LastTimeWeMeasured = micros(); // Stores the current micros so the next time we have a pulse we would have something to compare with.
if(PulseCounter >= AmountOfReadings) // If counter for amount of readings reach the set limit:
PeriodAverage = PeriodSum / AmountOfReadings; // Calculate the final period dividing the sum of all readings by the
// amount of readings to get the average.
PulseCounter = 1; // Reset the counter to start over. The reset value is 1 because its the minimum setting allowed (1 reading).
PeriodSum = PeriodBetweenPulses; // Reset PeriodSum to start a new averaging operation.
// Change the amount of readings depending on the period between pulses.
// To be very responsive, ideally we should read every pulse. The problem is that at higher speeds the period gets
// too low decreasing the accuracy. To get more accurate readings at higher speeds we should get multiple pulses and
// average the period, but if we do that at lower speeds then we would have readings too far apart (laggy or sluggish).
// To have both advantages at different speeds, we will change the amount of readings depending on the period between pulses.
// Remap period to the amount of readings:
int RemapedAmountOfReadings = map(PeriodBetweenPulses, 40000, 5000, 1, 10);  // Remap the period range to the reading range.
// 1st value is what are we going to remap. In this case is the PeriodBetweenPulses.
// 2nd value is the period value when we are going to have only 1 reading. The higher it is, the lower RPM has to be to reach 1 reading.
// 3rd value is the period value when we are going to have 10 readings. The higher it is, the lower RPM has to be to reach 10 readings.
// 4th and 5th values are the amount of readings range.
RemapedAmountOfReadings = constrain(RemapedAmountOfReadings, 1, 10);  // Constrain the value so it doesn't go below or above the limits.
AmountOfReadings = RemapedAmountOfReadings;  // Set amount of readings as the remaped value.
PulseCounter++; // Increase the counter for amount of readings by 1.
PeriodSum = PeriodSum + PeriodBetweenPulses; // Add the periods so later we can average.
} // End of Pulse_Event.
// Calibration:
// at very low RPM.
// Variables:
}  // End of setup.
  // Smoothing RPM:
  Serial.print(RPM);
}  // End of loop.
```[quote="ivanmitro, post:1, topic:1058572, full:true"]
CODE: ```cpp
// Calibration:
// at very low RPM.
// Variables:
}  // End of setup.
  // Smoothing RPM:
  Serial.print(RPM);
}  // End of loop.
[/quote]
Ich finde mich schon in Deinem Code schwer zurecht, aber LED finde ich garnicht.
Von daher ein Universalcode:
#include <Streaming.h>
//#define DEBUG
#ifdef DEBUG
#define DBG_PRINT(...) Serial << __VA_ARGS__
#define DBG_PRINTLN(...) Serial << __VA_ARGS__ << endl
#else
#endif
constexpr byte ledRotPin {2};
constexpr byte ledGrnPin {3};
#if (defined(ARDUINO_AVR_MEGA) || defined(ARDUINO_AVR_MEGA2650))
  delay(300);
#endif
  Serial << (F("\r\nStart...\r\n")) << endl;
  DBG_PRINTLN(__FILE__);
  DBG_PRINTLN( __TIMESTAMP__);
  for (byte b = 0; b < 100; b++)
    machLedAn(b);
    delay(100);
void machLedAn(const uint8_t wert)
  switch (wert)
    case 0 ... 40:
      digitalWrite(ledRotPin, HIGH);
      digitalWrite(ledGrnPin, LOW);
    case 61 ... 100:
      digitalWrite(ledRotPin, LOW);
      digitalWrite(ledGrnPin, HIGH);
  case default:
Das ist eine einfache Frage, also sollte die Antwort auch einfach sein:
const byte led_G =13;
const byte led_R = 12;
const int limitG_LOW = 400;
const int limitR_HIGH = 800;
   pinMode(led_G, OUTPUT);
   pinMode(led_R, OUTPUT);
   int value = analogRead(A0);
   digitalWrite(led_G , value < limitG_LOW);
   digitalWrite(led_R , value > limitR_HIGH);
Warum du wesentlich mehr Code hast, weiß ich nicht. Hast du evtl. eine andere Frage?
Sorry habe nicht das ganze code erklärt.
der code ist für RPM messen gedacht.
Und vielen dank für euere antwort.
Hast du jetzt Probleme damit,
  • eine Pulsgeschwindigkeit zu ermitteln,
  • zwei LED anzusteuern,
  • zu erkennen, was von beiden das Problem ist
  • einen Test zu schreiben, um eine Lösung auszuprobieren
  • die Test-Lösung in einen Gesamt-Sketch zu übernehmen
Das deutet eher auf den letzten Punkt hin. Du hast das Stichwort "Funktion" schon genannt.
Und im Titel "Serial monitor".
Dein Sketch könnte also so ähnlich aussehen:
void loop () {
   unsigned int rpm=getSpeed(); // dauert 500 .. 1000 ms
   Serial.println (rpm);
   setLed(rpm);
Die zwei Funktionen kannst du leicht einzeln schreiben und testen.
warte heißt des der ganze code was ich gemacht habe konnte ich so einfach machen?
void setLed( uint16_t val) {
   digitalWrite(led_G , val < limitG_LOW);
   digitalWrite(led_R , val > limitR_HIGH);
sehe ich so einfach, ja.
Die Funktion um den RPM Wert zu ermitteln ist wohl etwas aufwendiger. Wie lange darf sie blockierend dauern, wäre eine Frage...
Im Beispiel oben gab ich ihr sogar eine Mindestzeit, damit der Testausschrieb nicht so nervt.
