RPM based shift light
Hello,
I am having some trouble getting my shift light code working. I am able to get the shift light working using IF statements only, it will follow both up and down with a function generator, however all the LEDs are pulsing on and off, I suspect this is due to the timing of the loop re-checking the IF statements over and over again?
I found a similar project that was done several years and the code there uses FOR loops in addition to IF statements, I ran that code straight up and everything works great, however when I change the frequency ranges to work for my vehicle, I cannot get the lights to follow the freq output back down and also all the green LEDs come on at once instead of progressively.
[https://www.reddit.com/r/arduino/comments/515vsd/my_progressive_shift_light_because_racecar/[url/]
Below is my version of the working code from the above link, could someone review and tell me if they see anything obvious?
#ifdef __AVR__
  #include <avr/power.h>
#endif
#define PIN            6  //LED Data Pin
#define NUMPIXELS      9  //number of leds connected
Adafruit_NeoPixel pixels = Adafruit_NeoPixel(NUMPIXELS, PIN, NEO_GRB + NEO_KHZ800);
int i;
int rpm;
float ighigh,iglow;
unsigned long igfreq, igcal1, igcal2;
int cnt;
  pixels.begin();  // This initializes the NeoPixel library.
  Serial.begin(115200);  // connect to the serial port
  Serial.println("Frequency Counter");  //this is just for debugging so we can see what freq the controller is reading
  rpm = igfreq * 30
  //loop code, runs every cycle
  //measure period of tach signal
  ighigh = pulseIn(5,HIGH);
  iglow = pulseIn(5,LOW);
  igcal1=1000/((ighigh/1000)+(iglow/1000));
  //do it again
  igcal2=1000/((ighigh/1000)+(iglow/1000));
  //to filter out some noise, we only consider our measurement valid if they are similar in value, we accept the average
  if((igcal1-igcal2)<8)igfreq = (igcal1+igcal2)/2;
  //displaying measured freq through serial for debugging
  Serial.print(cnt++);
  Serial.print("  Freq: ");
  Serial.print(igfreq);
  Serial.print("  RPM:  ");
  Serial.println(rpm);
  delay(1);
  //Progressive lights from 7000-9000:  4 green lights, 2 yellow, & 3 red
  // @9100 all flashing red
  if(rpm>=7000 && rpm<9100){
    for( i=0;(i<NUMPIXELS)&&(i<=((igfreq-100)/16));i++){
      if(i <4){
        pixels.setPixelColor(i, pixels.Color(0,80,0));  //Green
        pixels.show();
      if(rpm>8000){
        pixels.setPixelColor(4, pixels.Color(50,50,0));  //Yellow
        pixels.show();
      if(rpm>8250){
        pixels.setPixelColor(5, pixels.Color(50,50,0));  //Yellow
        pixels.show();
      if(rpm>8500){
        pixels.setPixelColor(6, pixels.Color(100,0,0));  //Red
        pixels.show();
      if(rpm>8750){
        pixels.setPixelColor(7, pixels.Color(100,0,0));  //Red
        pixels.show();
      if(rpm>9000){
        pixels.setPixelColor(8, pixels.Color(100,0,0));  //Red
        pixels.show();
    for(i;(i<NUMPIXELS);i++){
      pixels.setPixelColor(i, pixels.Color(0,0,0));  //Off
      pixels.show();
  else if(rpm>=9100){
    for( i=0;(i<NUMPIXELS);i++){
      pixels.setPixelColor(i, pixels.Color(100,0,0));  //Red
      pixels.show();
      delay(20);
      pixels.show();
      delay(20);
  else for(i=0;(i<NUMPIXELS);i++){
      pixels.show();
](Reddit - Dive into anything)
when I change the frequency ranges to work for my vehicle ... all the green LEDs come on at once instead of progressively.
Did you adjust this line?
What was the original frequency range the code was written for, what is the range for your vehicle, and what/how did you change the code.
Other general comments: too many pixel.show(). This will cause flickering. Ideally you only want one in loop().
I did not, that is how it was in the base code. I hyperlinked the original, I made quiet a few changes. The original code was using a range of 100-216 hz, for my vehicle it needs to be 233-300 hz.
where would I put it pixel.show?
I might be wide of the mark here .. it may or may not help ..but ... I think I would work in the time units throughout and not convert into rpm - those division calculations must take a while ?
I’d also see if I could get rid of using floats too ( that may not be possible ).
“Case”
Might also be worth a look to set the switch points .
hammy:
“Case”
I tired it both ways, no change in the outcome.
What do you mean by switch points?
Sorry not very clear ..
I meant use the “case” statement to determine which lights are turned on when certain rpm point us passed rather than’ “if” rpm is bigger than whatever’
Rufio1013:
Let me be less subtle. You need to change that line.
