I am building an octocopter and I'm trying to figure out how to implement an rpm counter.
I purchased 10 of these sensors which will output a digital pulse.
I'm unsure if the pulse is a PWM signal or just a short pulse for every rotation. If its PWM I know how to handle that but the "short pulse" is where I'm having a problem. I have a digital oscilloscope so ultimately I'll be able to figure out once I get them ahhhhh the waiting time. If anyone knows please let me know!!!
I would need to create an arduino system that could count up to (10,000 rpm) or roughly 170 pulses per second ON EACH MOTOR so its essentially counting 170 pulses per second on 8 individual channels. This arduino system would be DEDICATED to nothing but RPM sensing and (8 channel analog current sensing) then outputting that information over serial or i2c. The serial information will be fed into a Beagleboard which will then act as the brain. In total I've got 3 arduinos + the beagleboard so that's why this arduino is dedicated, its just one of many sub systems.
What would be the best way to go about setting up an arduino for a task like this? Are there external IC's for the frequency counting I could get and hook up to the arduino or would I be able to do it in software RELIABLY?
Thanks a lot,
