At a sawmill we have a chipper which runs off of a ac motor. It has a downward sloped ramp that goes into the chipper that vibrates the scrap wood into the chipper (called the shaker). The chipper gets jammed up when too much scrap wood tries to go all at once. I want to create a circuit so when the rpm's drop at a designated number, it will cut off the shaker. Then when the rpms go past a designated number, it will cut back on. Ive got some ideas from several different projects but not sure how to approach it.
Could i use something like this: "Arduino RPM Counter / Tachometer Code -" then change the code for my rpm cut on and cut off points?
Once i figure out the circuit and coding then im going to connect it to a solid state relay that will be used to switch it on and off.
Any advice would be greatly appreciated.
