RPM Display skipping to 0 and 5000
Hey guys,
can somebody help me with this problem? Attached i have a photo
of the Display skipping to 0 and 5000 all the time.
rpm
#define  B_PHASE 2
#define INDUCTIVE_SENSOR  3
double autodepth;
double cbdwell;
double cbdepth;
boolean auto_case = false;
volatile unsigned long RPMN1count = 0;
volatile unsigned long RPMN1period = 0;
unsigned long RPMN1 = 0;
unsigned long prev_rpm = 0;
volatile double Position = 0;
double prev_pos = 0;
double RealPos = 0;
unsigned long tx_millis;
unsigned long relay_millis = 0;
unsigned long cnt = 0;
boolean is_relay_on = false;
const int RELAY_PIN = 7;
const double POSITIONAL_SHIFT = 0.1978022F;
enum ModeM {
  Auto,
  cbdep,
  cbdw
}; ModeM Mode;
  pinMode(A_PHASE, INPUT_PULLUP);
  pinMode(B_PHASE, INPUT_PULLUP);
  pinMode(RELAY_PIN, OUTPUT);
  RPMN1count = micros();
  attachInterrupt(1, N1, FALLING);
  attachInterrupt(digitalPinToInterrupt(B_PHASE), interrupt, RISING);
  tx_millis = millis();
  relay_millis = millis();
    Serial.print("baud=115200");
    Serial.print("\xFF\xFF\xFF");
    Serial.end();
  // Position calculation
  RealPos = Position * POSITIONAL_SHIFT;
  if ((RealPos < 0.2) && (RealPos > -0.2)) {
    RealPos = 0;
  // RPM calculation
  if ((micros() - RPMN1count) > (3 * RPMN1period)) {
    RPMN1 = 0;
  else if ( RPMN1period != 0) {
    //noInterrupts();
    RPMN1 = (60000000UL / RPMN1period); //Two signals per rotation.
    //interrupts();
  // Mode control
  if (Mode == Auto) {
    automode();
  // Communication
  check_data();
  if ((millis() - tx_millis) > 100) {
    if (prev_pos != RealPos) {
      Serial.print("t13.txt=\"");
      Serial.print(RealPos, 1);
      Serial.print("\"");
      Serial.print("t14.txt=\"");
      Serial.print(Position);
      Serial.print("\"");
      prev_pos = RealPos;
    if ( prev_rpm != RPMN1) {
      Serial.print("page1.n1.val="); // Changing the value of box n1
      Serial.print(RPMN1);
      prev_rpm = RPMN1;
    //Serial.println();
void N1() {
  RPMN1period = micros() - RPMN1count;
void interrupt() {
  if (digitalRead(A_PHASE) == HIGH)
    Position++;
    Position--;
  cnt++;
void check_data() {
  if (Serial.available()) {
    String data_from_display = "";
    delay(30);
    while (Serial.available()) {
      data_from_display += char(Serial.read());
    if (data_from_display == "ZERO") {
      Position = 0;
      Serial.print("\"");
    } else if (data_from_display.charAt(0) == 'a') {
      autodepth = (data_from_display.substring(1)).toDouble();
      Mode = Auto;
      //Serial.println(autodepth,5);
    } else if (data_from_display.charAt(0) == 'b') {
      cbdepth = (data_from_display.substring(1)).toDouble();
      Mode = cbdep;
      //Serial.println(cbdepth,5);
    } else if (data_from_display.charAt(0) == 'c') {
      cbdwell = (data_from_display.substring(1)).toDouble();
      Mode = cbdw;
      //Serial.println(cbdwell,5);
void automode() {
  if (!is_relay_on) {
    if ((autodepth == RealPos) && (RealPos != 0)) {
      digitalWrite(RELAY_PIN, LOW);
      is_relay_on = true;
  if (is_relay_on) {
    if ((millis() - relay_millis) > 2000) {
      digitalWrite(RELAY_PIN, HIGH);
Welcome to the forum.
Where did you get this code, or the idea you are trying to follow with it?
Why are some lines commented?
Turning on and off interrupts is going to be an essential part of your algorithm. Either the original author misplaced those lines, or you did. Commenting them out means you aren't doing something that needs be done, even if you weren't doing it in the correct place(s).
a7
A friend of mine corrected my Code. Do you think it would work with intterupts?
