I'm doing research for a dynamometer, how to keep engine rpm at the motorcycle remains stable and can be measured simultaneously with other sensors ? thank you
coulden't understand your question that much but you if you can attach a little optical wheel you will be able to measure the RPM of the shaft with a rotary encoder, an arduino and some software. ![]()
you might need to dive into PID - Arduino Playground - PIDLibrary -
