Hi, i´m new in the forum, i have read some proyects about rpm gauges, many of them uses lcd display 16x2, for space issues y would like to use the nokia 5110 lcd display, somebody can helpme with the code? thanks
What is you ability with programming and electronics?
Weedpharma
i´ma beginer in both : O : Smiley-confunden:
Well, I suggest to start at the beginning... First try it with a normal 16x2 LCD and work your way up from there.
And yes, it can be done. But the most fun you'll have by start at the beginning and always first try to figure stuff out by yourself...
Do a search using the search box at the top of the page. There are many projects using LCD and you will be able to learn a bit of programming as well.
We will help but you need to learn the basics.
Weedpharma
thanks, i´m tryin to study the code, it´s hard to me, but i will do! ![]()
