So, iv'e been fiddling around with different methods of measuring RPMs last couple of days.
I did find this thread on the forum:
https://forum.arduino.cc/index.php?topic=416602.0
and the post by dlloyd peaked my interest.
So i tried it out, and it seems to work great, mostly.
At a bit higher frequencies, say, over 200Hz, there is some measurements that reads to high.
output [you can see the freak value in the middle]:
17026.11 RPM 283.77 Hz
17016.45 RPM 283.61 Hz
34052.21 RPM 567.54 Hz
code:
const byte rpmInputPin = 2;
const byte rpmMeasurementCycles = 2;
const byte printInterval = 500;
volatile unsigned long startTime, stopTime;
volatile byte rpmCount, testState;
unsigned long rpmPeriod, currentMillis, previousMillis = 0;;
float rpmFrequency, rpm;
pinMode(rpmInputPin, INPUT);
attachInterrupt(digitalPinToInterrupt(rpmInputPin), rpmMeasure, RISING);
if (testState == 2) EIMSK &= ~bit(INT0); // disable INT0 interrupt
currentMillis = millis();
if (currentMillis - previousMillis >= printInterval) {
if (testState == 2) { // testing completed, results are ready
noInterrupts();
rpmPeriod = (stopTime - startTime) / rpmMeasurementCycles;
interrupts();
rpmFrequency = 1000000.0 / rpmPeriod;
rpm = rpmFrequency * 60.0;
Serial.print(rpm);
Serial.print(" RPM ");
Serial.print(rpmFrequency);
Serial.println(" Hz");
rpmCount = 0;
testState = 0; // clear testState
EIFR |= bit(INTF0); // clear INT0 interrupt flag
EIMSK |= bit(INT0); // enable INT0 interrupt
void rpmMeasure() {
switch (testState) {
case 0:
startTime = micros();
testState = 1;
case 1:
rpmCount++;
if (rpmCount == rpmMeasurementCycles) {
stopTime = micros();
testState = 2;
Could there be something with the serial routine that is bothering it?
Thanks!
