RPM Meter with Hall Effect Square Encoder Sensors
RPM meter with quadrature encoder using Hall effect sensors.
I use KY-035 sensors that have an AH49E analog sensor. For each motor I have placed two mechanically separated sensors in quadrature to determine the direction of rotation.
With the use of external interruptions I control the state of sensors 1 of each pair and with internal interruptions (Timer1) I count the time of the period to determine the frequency and the RPM. It used exponential decay by not detecting changes in sensor 1 of each encoder, either because the speed has dropped considerably or the motor has stopped.
On each axis of the motors I have improvised an encoder with neodymium magnets.
For starting and turning control of each motor, I use operational amplifiers (LM324N) with a joystick and a driver (L293N and L298N).
Last but not least, I have used a Schmitt Trigger inverter (SN74LS14N) to nullify the transient effect of each sensor, which avoids false readings and thus obtain with enough precision the revolutions and direction of rotation of each motor.
Code
Video
RPM Meter Direction
Use Square Encoder with Hall effect sensors
By DrakerDG (c)
https://www.youtube.com/user/DrakerDG
#include <SPI.h>
#include <TFT_ST7735.h>
#include <SimplyAtomic.h>
#include <TimerOne.h>
#define	 GREEN 0x07E0
#define YELLOW 0x07FF
#define DC A0 //9
#define RS A1 //10
#define CS A2 //11
// Sensor pins
const byte PinX[4] = {2, 3, 10, 11};
// Limit of microseconds
const long uSeg = 100000;
// Left position RPM labels
const byte x1 = 75;
// Pulse timer counters
volatile unsigned long pwc[2];
// PWM periods
volatile unsigned long pwm[2];
// RPM values
unsigned long rpm[2];
// States of the second sensors
volatile bool Sen[2];
// Count variable printing millis
unsigned long prT = 0;
TFT_ST7735 tft = TFT_ST7735(CS, DC, RS);
void CountSA(void);
void CountSB(void);
void RPMc(void);
void Draw_Table(void);
void Print_Data(void);
void setup(){
  tft.begin();
  tft.setRotation(1);
  tft.clearScreen();
  tft.setTextWrap(true);
  tft.setTextColor(YELLOW, BLACK);
  tft.setCursor(0, 0);
  Draw_Table();
  for (byte i=0; i<4; i++){
    pinMode(PinX[i], INPUT);
  for (byte i=0; i<2; i++){
    pwc[i] = uSeg;
    pwm[i] = uSeg;
    rpm[i] = 0;
  // Interrupt to count period time
  Timer1.initialize(100);
  Timer1.attachInterrupt(RPMc);
  // Interrupt of Sensor 1 of Motor A
  attachInterrupt(digitalPinToInterrupt(PinX[0]), CountSA, FALLING);
  // Interrupt of Sensor 1 of Motor B
  attachInterrupt(digitalPinToInterrupt(PinX[1]), CountSB, FALLING);
void loop(){
  Print_Data();
void CountSA(){
  // 2nd sensor value
  Sen[0] = 1 & (PINB >> 7);
  pwm[0] = pwc[0]; // Save the period
  pwc[0] = 0; // Reset the timer
void CountSB(){
  // 2nd sensor value
  Sen[1] = 1 & (PINB >> 6);
  pwm[1] = pwc[1]; // Save the period
  pwc[1] = 0; // Reset the timer
void RPMc(){
    // Increase the time counter
    pwc[i]++;
    if (pwc[i] > (uSeg)){
      // Limit the timer & period
      pwc[i] = uSeg;
      pwm[i] = uSeg;
void Draw_Table(){
  // Code to draw the table on screen
  tft.drawFastVLine(22, 0, 128, WHITE);
  for ( int i=0; i<11; i+=1 ){
    tft.drawFastHLine( 20, 5+i*12, 4, WHITE);
    if (!(i&1)){
      tft.setCursor( 0, i*12 + 2);
      tft.print((10.0-i)*0.5, 1);
  tft.drawFastHLine( 20, 125, 128, WHITE);
  tft.setTextSize(1);
  tft.setCursor(x1, 10);
  tft.print("Motor A");
  tft.setCursor(x1+30, 45);
  tft.print("RPM");
  tft.setCursor(x1, 70);
  tft.print("Motor B");
  tft.setCursor(x1+30, 105);
  tft.print("RPM");
  tft.setTextSize(2);
void Print_Data(){
  unsigned long nwT = millis();
  // Calculations and prints every 10ms
  if ((nwT - prT) > 10){
    prT = nwT;
    char sRPM[10];
      //RPM
      tft.setCursor(x1, 25+60*i);
      // Protects math calculation
      ATOMIC()
        // Detect Rotation Decrease
        if (pwc[i]>(pwm[i]*2)){
          pwm[i] *= 2;
          pwm[i] = constrain(pwm[i], 0, uSeg);
          pwc[i] = pwc[i]*2;
        /* detects or not the
        rotation of the motors */
        if (pwm[i] < uSeg) rpm[i] = 6*uSeg/pwm[i]; // Detects rotation
        else if ((rpm[i] > 0)&&(pwm[i] == uSeg)) rpm[i] = int(rpm[i]/2); // No rotatiom
        // Limits the value of RPMs
        rpm[i] = constrain(rpm[i], 0, 9999);
      dtostrf(rpm[i], 4, 0, sRPM);
      // Print the RPMs
      tft.print(sRPM);
      int valX = rpm[i]*120/500;
      // Prints the RPM bars
      tft.fillRect(30+15*i, 0, 10, 125 - valX, BLACK);
      tft.fillRect(30+15*i, 125 - valX, 10, valX, GREEN);
      tft.setCursor(x1-15, 25+60*i);
      /* Determines the direction
      of rotation of the motors.
      Prints + if it turns CW and
      - if it turns CCW */
      if ((rpm[i] == 0)&&(pwm[i] == uSeg)) tft.print(" ");
      else if (Sen[i]) tft.print("-");
      else tft.print("+");
