RPM obtain with ELM 327 (STN1110) for those who lookin
Good working tested Sketch for MEGA with ELM237 and Sparkfun LCD to obtaining an RPM of your car engine from OBD.
For those who lookin to start with.
Simple ways...
//MAterials Arduino MEGA
//Sparkfun Serial LCD KIT
//ELM327 wired one...But you can use a bluetooth one then this serial must be with bluethooth device
//ATDP DESCRIBE CURRENT PROTOCOL
// ATE(0,1) echo(on,off)
String Str;
int check;
  Serial.println("Start");    //This serial monitor see what's UP
  Serial1.begin(9600);
  Serial1.print("ATZ\r");  // This Serial hooked with ELM327 (I wish to get here higher baund)
  Serial1.print("ATE0\r");  //Echo off
  delay(50);
  Serial3.begin(115200);       //This one is LCD
  //Str = Serial1.readString();       // Everything what ELM answers we got in the String Str
               Serial1.setTimeout(1000);            //We need here slow down or ELM sends garbidge
               Serial1.flush();                    // Yes I want it here
               Serial1.print("010C\r");            // First RPM PID
               Str = Serial1.readString();         //LOvely function. Geting respond
               Serial.println(Str);              //This one for debag you know
               check = 1;  // 3rd IF reset
  if (Str.startsWith("SEARCHING"))  //When you first power up the system, ELM automaticaly scans for car protocols(aftr a RPM PID) when its doing that its answers with Searching word
                                    // Sending PID wait for an answer... This must be improve though by Serching for pratacol function first and then acctually sending a target PID
     Serial3.write(0xFE);           //Neded for LCD
     Serial3.write(0x01);
     Serial3.print("Serching");
     Serial.println("IF1");
     delay(3500);                     //We need this delay for ELM find and hook the right protocol when ing ON
  if (Str.startsWith("NO"))
     Serial3.write(0x01);            // When ELM actually knows the car protocol but can't obtin data from it because ingitin  is off.
     Serial3.print("NO DATA");
     Serial3.print(" ");
     Serial3.print("ING OFF");
     Serial.println("IF2");
     delay(3500);
   if (Str.startsWith("41"))
         Serial.println("IF Suka 3");
         delay(3500);                            //debug
          while(check == 1)
                     Serial1.setTimeout(90);                     //Speed up the process!!!... You can't get it lower i guess...
        // The  baund rate on this port may can help to get faster respond from ELM
                     Str = Serial1.readString();              //Calling aggain with diferent speed..
                     Serial.println("While");
                     String A = Str.substring(6,8);       //It is was pain to get it right... Cause STRTOL you can specify the begining of string but not the end or I don't get it. so that's way in to 2 Strings
                     String B = Str.substring(9,11);
                     Serial.println(A);
                     Serial.println(B);
                       //((A*256)+B)/4
                      int long Ch = ((strtol(&A[0], 0, 16) * 256) + strtol(&B[0], 0, 16)) / 4;     //The magic formula what gets actual DEC number of HEX answer
                     if (Str.startsWith("STOPPED"))
                              Serial.println(Serial1.read());           //Getting away from while loop if Ignition Off and reastarting ELM at the same time
                              check = 0;
                     Serial3.write(0x01);              //reset LCD and Put  the cursor to the TOP left position
                     Serial3.write(0x0D);               //Put the cursor to the beginnig of second rol
                     Serial3.print(Ch);
                     Serial3.print(" Rpm");
//By Slavka85 /1.9.14/
If you like it and use it like me too by clickin
